Can you glue the bottoms of laminate flooring together?
Forum topic by kiwilynne posted 06-20-2021 06:22 AM 660 views 0 times favorited 9 replies Add to Favorites Watch
View kiwilynne's profile
kiwilynne
304 posts in 943 days
06-20-2021 06:22 AM
Topic tags/keywords: question flooring laminate upcycle
I recently got some leftover (about 4 square meters) laminate oak flooring and I’m currently devising what projects I can do with them (I won’t be using them for flooring). Does anyone know if it is feasible to glue the undersides of the flooring (the laminated sides) together so that the oak edge is on both the top and bottom? I’ll obviously do a test run but thought I’d ask, in case someone has had the same idea in the past.
-- Lynne, New Zealand - Crikey, Aussie is another country, Bro.
9 replies so far
View Wood_Scraps's profile
Wood_Scraps
172 posts in 184 days
#1 posted 06-20-2021 06:47 AM
Like you indicated, just do a test run on some small pieces. Maybe experiment with wood glue, CA glue, etc. I’d think a little sanding first might help with adherence.
View Jim Jakosh's profile
Jim Jakosh
26475 posts in 4270 days
#2 posted 06-20-2021 08:22 AM
I don’t see why not with the right glue. BUT, much of the flooring has a titanium finish on it and that is very hard on cutters..even carbide. Check out the finish !
Cheers, Jim
kiwilynne
#3 posted 06-20-2021 07:13 PM
Hi Jim :)
Thanks for the tip about sanding. From what I could gather reading up on the specific flooring type, it has a low sheen poly coating.
View splintergroup's profile
splintergroup
5484 posts in 2387 days
#4 posted 06-20-2021 10:19 PM
Based on the stuff I’ve used (about 1/4” thick), the surfaces are very slick.
Saying that, If I was to do what you are intending I’d rough up the glue surfaces with a sander, maybe 80 grit and plan on burning through a few discs to get a nice even scratch pattern over 100%.
To keep the stacks thickness as even as possible, I’d opt for some strong (not water base) contact cement applied per instructions and spread out with a toothed mastic spreader to get as even (in thickness) coverage as possible.
The joints between planks is a weak point for flexing so I’d consider overlapping the seams between top and bottom by 50%.
View SMP's profile
SMP
4459 posts in 1070 days
#5 posted 06-21-2021 12:21 AM
Depends on brand and model. Some of that stuff is like pressed cardboard. So sure you can glue it together, then try to rip it apart, you’ll see pretty quickly
View squazo's profile
squazo
245 posts in 2810 days
#6 posted 06-22-2021 03:14 PM
Isn’t there specific glue made for glueing it down? Or maybe it’s a floating floor. I second contact cement.
View bbc557ci's profile
bbc557ci
631 posts in 3239 days
#7 posted 06-22-2021 04:49 PM
What is the sub straight or core material, to which the oak is secured to?
-- Bill, central NY...no where near the "big apple"
kiwilynne
#8 posted 06-22-2021 07:28 PM
- bbc557ci
Hi Bill, the flooring in question are these:
https://www.mitre10.co.nz/shop/sens-element-laminate-flooring-mocha-oak/p/369273
There appears to be the top oak veneer, resting on what looks like MDF with the laminate on the bottom. Made in Belgium, if that helps.
kiwilynne
#9 posted 06-22-2021 07:30 PM
Isn t there specific glue made for glueing it down? Or maybe it s a floating floor. I second contact cement.
- squazo
Hi squazo – these are click-in floors, so I assume its a floating floor. I will probably be securing the click-in sections with glue as I am looking at making some chests and maybe a small table.
