I am beginning to prep for a move from WA (Tacoma) to Wisconsin (Waukesha). I have been wrestling with the idea of how to move the equipment that I have accumulated.
Some background. I have a SawStop PC, Laguna 18 HD, Laguna 14 BX, Powermatic 12 Inch Helical jointer, a Powermatic 20 helical planer, a 19/38 belt sander, a Jessem routertable, a Clearvue dust collector, plus various odds and ends. I acquired these over the last couple of years while I had the cash flow to support my hobby/habit. Many suggest just selling off your equipment, and buying new when you get to your next location. I will not be in that position as I am now retired and my significant other keeps a little closer watch on the bank balance. So moving is what suspect I have to do.
Options that I can think of are:
rent a Penske 26-28 foot truck, load, drive, unload myself - with a little help on both ends. Problem with this idea is that I cannot find a truck this size with a lift gate, They have them for local use, but not one way trips. So now I would have to rent a fork lift - which I have no experience with
Using PODS. I have done this furniture and household goods with good results, but not sure about heavy and somewhat fragile equipment.
Using a moving company has been suggested to me. I have significant reservations about this idea, but if anyone has had a good experience, please speak up.
PODs sound like your best bet, just keep an eye on the allowed weight and pack (in boxes or vacuum bags) all your towels, linens and bedding in between. You might also want to also create a sort of wooden exoskeleton around some of the more fragile machines to keep them in place and from bumping one another. I suspect this option would also be the least expensive given you wouldn't need to rent a forklift or a truck + fuel.
When I moved my shop machines 580 miles, I used my truck and a single axle utility trailer containing:
Delta AP400 dust collector
Grizzly G0440 cyclone dust collector
Craftsmas tube lathe
JET 12" disc/ 6×48" belt sander
Delta DP600 drill press
Delta Unisaw
Grizzly 20" bandsaw
Delta DJ20
and 200-300lbs of wood I couldn't bear to part with.
It was January in OH and despite being a bit of a PITA, it was the least painful part of the whole move.
I moved my shop just a short distance but I loaded and unloaded all of it by myself. I used a PODS because to load and unload all i needed was a 3 1/2" tall ramp. I was younger when I did this I was only 70 then.
I had a friend move about a year ago from one side of the state to the other side of the state. Not a large shop but full of heavy woodworking equipment and lumber. He hired someone to come in and do a turnkey move for him.
Move went flawless and he was back to woodworking in his new home location in less than 2 weeks. He told me if he ever got a decision right, the decision to get someone to move his shop for him was the most least stressful thing he thinks he had ever done.
He told me not having the stress of trying to figure the logistics out, load, move and unload his shop again in a new location was well worth the money he spent.
While all that was being done his wife was getting new home ready when the moving company truck arrived and he was getting his new shop ready for his old shop to arrive. Truck got there, backed up to his new shop in their backyard, unloaded and put the equipment where he wanted. No stress.
Doing it yourself gives some peace of mind knowing your treasures will be looked after the entire trip, but also having some professional movers with insurance provides relief at the end destination when everything arrives intact.
The Pods option seems to fit nicely in the middle ground, you get to load/unload and the movers only deal with the transport, assumingly not making a mental note of what to swipe as they pack it all up.
Some other things to consider is to "safe" your equipment. Disassemble/lock down items that should not see vibrations or odd loads. The band saw table comes to mind, remove it. These are attached by usually spindly trunions which can easily snap if the table gets a good jostle or someone decides to lift/move the machine by grabbing onto it.
Look into UPack. If there is enough stuff, they drop a trailer (a real truck trailer), you load it, they drive it, and then you unload it. You pay by the linear foot of space you use in the trailer. Then you hire a local moving company to pack it. Depending on how much risk you want to take, you can hire another moving company to unpack, or just hire day labor to do it (on CL). This works out to be much cheaper than a full moving company job, but you have pros moving your stuff and packing the truck. Did this moving my mother in law across the country. Worked out great. The moving company in CA were really good, and brought the consumables needed to do a good job. We rented moving blankets from UHaul, which also works out great. When I opened the trailer in PA, it looked EXACTLY like what it looked like leaving CA. Nothing moved, at all. It's not an air-ride trailer, but if it's packed well, so what?
My sister and her entire clan just moved from WA to WI last fall, way up in the WI back woods. They went with pods for the heavy stuff but as someone mentioned watch the weight limits.
There are many threads on LJ where folks ask how to move shop full of equipment.
Tons of tips, and suggestions in each one. Try search for 'move shop' please?
I have moved to 4 different places in last 15 years, so I have different perspective than most. All my stuff is on wheels, all of my parts and stored tools are packed in totes, placed on rolling wire rack shelves; and can move the entire shop out into the driveway/truck/trailer in about an hour (if the place is cleaned up), excluding the wood rack hanging on wall. LOL
From a high level view make this suggestion:
Take inventory of all tools, and equipment.
Then go online in the new area where you will live and check out used tool market. If you can buy similar/better tools for similar money as selling locally; don't move the big tools - sell them and use the chance to upgrade/change your shop. Moving tools is expensive, and time consuming. If you pay someone to PROFESSIONALLY pack and move your work shop stuff, it adds ~$1-$1.50 per pound to price of item. So moving a 400lb saw, magically adds $400 to your out of pocket cost. Another hidden gotcha with large tools is how fragile is the tool. You have to spend time tearing down all you tools for move, and the movers don't know what is breakable or not. I.E. Never move a band saw with table attached! Always assume hand wheels will be used as handle to pick stuff up, so remove them! There is ton of work involved if you let some one less knowledgeable touch your tools.
Bottom line: Constantly ask yourself these questions:
- Is it worth adding money to cost of this old tool via move, and will it be worth same or more after move?
- Do I use the tool enough to spend money/time moving it?
- How can this tool be damaged during move, and should you tear it down for move, or sell it and reassemble a different/new tool at new shop.
A shop move can be a fresh start? But have to make hard decisions as you clean up, downsize stuff not needed, and work you arse off for better shop in new place.
If it's OK with your significant other to pay for the moving (relocating) of your equipment. To save muscle, back ache and head ache issues. I'd consider asking your significant other, if you sell your equipment, why not add the amount from the selling of equipment, to the amount saved from not moving the equipment. And use the combined amount, to replace after the move. This way to have a higher nest egg to repurchase, just a thought.
Pods work, I did it. In fact my shop equipment (table saw, band saw, joiner, etc) sat in a pod for over a year before I unpacked them and everything was fine). Pods are low, easy to load, just drop them in your driveway and roll the stuff on and off.
I ended up using North America Van Lines for my move. Equipment and wood arrived in good shape. I got a 30' x 40' x 12' stick built detached garage that I have slowly been turning into my new shop. 2×6 studs. Had one 120v outlet and minimal lighting. So far I have gotten wiring done, insulation consisting of 2" of foam and 4" cellulose in the walls, and 14" of blown insulation in the ceiling. and sheet rock hung. LP tank and furnace are in, minisplit will follow later. New lighting and ceiling fan will be done by me this week. Given the supply chain and worker shortage it has been a challenge, but I am pleased so far.
Moving is a pain, I've done it a couple of times. But the excitement and fun of a new shop makes it all better!
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
