Anyone put a wheel on a yost vise?
« back to Hand Tools forum
Forum topic by Notw posted 06-10-2021 03:26 PM 409 views 0 times favorited 18 replies Add to Favorites Watch
View Notw's profile
Notw
1005 posts in 2870 days
06-10-2021 03:26 PM
The leg vise on my workbench is made from a Yost vise and the criss cross portion from Benchcrafted. The yost vise appears to have a spring pin holding the arm on. I am wondering if anyone has ever removed this and put a wheel like the benchcrafted vises on before?
-- You got to be tough if your going to be stupid. Jason
18 replies so far
View SMP's profile (online now)
SMP
4148 posts in 1023 days
#1 posted 06-10-2021 03:40 PM
I have considered it, but have had trouble finding a wheel for a decent price that would fit. I keep checking in antique shops for old wheels from various things but they all are either too small or too large.
View HokieKen's profile
HokieKen
17904 posts in 2256 days
#2 posted 06-10-2021 04:07 PM
- SMP
Ditto. I never did track down a wheel I wanted to use. Eventually I replaced the screw with a Hovarter mechanism though so a wheel isn’t all that practical now so I quit hunting.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Foghorn's profile
Foghorn
1242 posts in 504 days
#3 posted 06-10-2021 05:14 PM
Something like this? It would have to be drilled to the correct shaft diameter. https://www.grizzly.com/products/grizzly-spoked-handwheel-8/h3193
-- Darrel
View Notw's profile
Notw
#4 posted 06-10-2021 06:16 PM
yes Foghorn, just didn’t know if someone had done it before and if it was worth the time
HokieKen
#5 posted 06-10-2021 06:38 PM
The only downside to a wheel on a leg vise IMO is that you’re probably going to want a handle sticking out. That puts the projection further out than the handle you have. I could foresee that bruising my thighs more than once…
View Notw's profile
Notw
#6 posted 06-10-2021 06:41 PM
good point, thigh would be the least of my worry
SMP
#7 posted 06-10-2021 07:01 PM
For me it was more about looks, i wanted something cooler/older looking. Closest I found was in some antique store it was a large metal pipe fitting with a valve that had a large cast wheel. But they wanted over $100 for the whole thing. I was trying to keep it around $30-50, hence my slow search continues…
View Notw's profile
Notw
#8 posted 06-10-2021 07:24 PM
I was thinking of something similar to my tail vise as it has a wheel.
View Don W's profile
Don W
20089 posts in 3685 days
#9 posted 06-11-2021 10:56 AM
Similar maybe?
https://www.lumberjocks.com/donwilwol/blog/34022
View Notw's profile
Notw
#10 posted 06-11-2021 11:49 AM
Similar maybe?
- Don W
Ohh thats cool, something new to look for when rust hunting
HokieKen
#11 posted 06-11-2021 02:46 PM
That’s exactly the kind of thing I searched for but never found. My biggest problem was I didn’t want anything bigger than 8” because it would be too big and I wanted minimum projection/depth sticking out. And the few cool wheels I did run across that were small enough to suit me had hubs that were too small for the screw shaft.
View Notw's profile
Notw
#12 posted 06-11-2021 02:49 PM
Adam Savage just had a one day build video where he put a handle on his andy klein vise, the handle folded down so it didn’t project out as much.
HokieKen
#13 posted 06-11-2021 03:01 PM
Here’s one along the lines of several I considered. With this one, you’d have to bore out the hex and make a bushing to reduce it to fit your shaft (which is .950” diameter if I recall correctly).
View 2Goober's profile
2Goober
53 posts in 719 days
#14 posted 06-11-2021 07:35 PM
Thanks for posting this question. I’m building a workbench now and it gave me a idea. (My ideas makes little children wet the bed at night). I found a 4” and a 8” cast iron hand wheel on Amazon for $18 and $44. They have to be drilled to fit but they don’t have a handle sticking out. That’ll keep me from tightening the vice more than I should. It’s the Morton cast iron hand wheel that’s not chrome plated. Looks like a similar color as the Benchcrafted but a WHOLE lot cheaper.
Don W
#15 posted 06-12-2021 01:12 AM
That s exactly the kind of thing I searched for but never found. My biggest problem was I didn t want anything bigger than 8” because it would be too big and I wanted minimum projection/depth sticking out. And the few cool wheels I did run across that were small enough to suit me had hubs that were too small for the screw shaft.
- HokieKen
I’ve got an old tractor steering wheel that was intended for it, but liked the weight. It acts like a fly wheel. Almost like a quick release. Want it closed, just give it a push and the weight carries it shut or open.
I did have one issue with it. One day I was in a hurry and a set a piece of 5/4 oak in front of it. Still in a hurry I wanted the vise open so I grabbed the handle and gave it a hardy spin. Well my fingers were between the handle and the oak, with the fly wheel in motion. I did several laps around the shop not sure if I should cry, pee my pants or pass out, before I dared look at my fingers. Luckily nothing was broke, but NOTHING get set in front of it now.
