blind dado on a table saw
Forum topic by Karda posted 06-08-2021 06:24 PM 294 views 0 times favorited 13 replies Add to Favorites Watch
View Karda's profile
Karda
3184 posts in 1673 days
06-08-2021 06:24 PM
Hi, I want to make a double blind dado on my table saw for a dovetail box I am making. how do you do this safely. I can find many videos on making a dovetail box on utube but they only show the dovetails. I can’t do it on my sled
13 replies so far
View Aj2's profile
Aj2
3891 posts in 2918 days
#1 posted 06-08-2021 06:38 PM
Are you sure you want to use a table saw and dado blade.
A router with or without a table is a lot more sensible.
A router is the method I use
Good Luck
-- Aj
View brtech's profile
brtech
1141 posts in 4042 days
#2 posted 06-08-2021 06:39 PM
A picture would help. What is the dado for if the box uses dovetails? To hold the bottom panel?
View Madmark2's profile
Madmark2
2842 posts in 1708 days
#3 posted 06-08-2021 06:43 PM
Don’t.
As others have said the router is the better & safer solution. The “stopped” TS dado, won’t. The curve at the ends will make the fit both sloppy (ends ill defined) and prone to binding.
-- The hump with the stump and the pump!
View therealSteveN's profile
therealSteveN
8009 posts in 1694 days
#4 posted 06-08-2021 06:45 PM
Safely is the key word. Against a fence I think nothing about using stop blocks, and dropping a piece of stock on a spinning router bit at shallow depth to run against the fence to the far side stop block. Do that all the time. Increase depth a few passes and done. You will have chisel work if you need square edges, but I find it easier to round off the tenon part.
Because of that blade coming over the top, right at ya. I get a little tight in the end zone thinking about that on a TS, so I use the router table. I have seen video of people explaining how to, (pretty much the same as RT) on U tube, still I find my warm and fuzzy zone absent. Plus with the blade it makes a graduated depth at both ends, where the router bit can bring you right to the line full depth.
-- Think safe, be safe
Karda
#5 posted 06-08-2021 06:47 PM
I have 2 options chisel or TS. I do not have a router. I am using the dados for the bottom and lid. I know the slot will be shallow on the end, will have to clean it up with a chisel
View JackDuren's profile
JackDuren
1600 posts in 2079 days
#6 posted 06-08-2021 07:54 PM
It’s done all the time but demands your full attension, but safer with a router.
Did I mention I lost the tips of two fingers in 1985 doing blind dados..
therealSteveN
#7 posted 06-08-2021 08:20 PM
Well that pretty well cakes it. Nothing tells a story as completely as a picture.
Karda has anyone told you how much your going to love your new router table set up, let me be the first. You do enough woodworking you will see hundreds of uses for it.
View CWWoodworking's profile
CWWoodworking
1888 posts in 1299 days
#8 posted 06-08-2021 08:21 PM
Run the dado and glue a piece back in.
Glue on fingers doesn’t hurt.
View RClark's profile
RClark
139 posts in 3305 days
#9 posted 06-08-2021 08:50 PM
- CWWoodworking
^^^^This^^^^
I’ve tried blind dadoes on the table saw. Chiseling that curve out is a pain, as far as I’m concerned.
If you must do a stopped cut on the table saw, I’ve found it’s best to have a stop button that can easily be activated with a knee bump. That way you can get the work piece to your stopping point and then bump the saw into the off position without moving your hands (which are hopefully well out of the path of the blade.)
Filler blocks are useful in many circumstances. Of course, if your project involves highly figured wood, then they are more difficult to hide.
-- Ray
View Lazyman's profile
Lazyman
7136 posts in 2507 days
#10 posted 06-08-2021 08:54 PM
Cut a full dado and glue in blocks on the ends is probably the only way I would do this on a table saw
View Ocelot's profile
Ocelot
3133 posts in 3758 days
#11 posted 06-08-2021 09:05 PM
Hmmm.
No need for a stopped dado. It can still be hid even without a piece glued in.
I’ve done it with a box joint all on the table saw with through cuts and no gaps.
If you carefully space the fingers on the joint and vary the depth, you can use a through dado and still have no gap.
I don’t have a photo on my work computer.
-- I intended to be a woodworker, but turned into a tool and lumber collector.
View robscastle's profile
robscastle
7948 posts in 3324 days
#12 posted 06-08-2021 09:21 PM
This information may be of interest.
WHAT YOU SHOULD DO
If part of a finger is amputated, the priority is to look after them.
Sit them down, reassure them and maybe call Jack Duren! ... grab a cloth to apply direct pressure to the stump, elevate the injured hand above the level of the heart. Do not worry about the amputated part until bleeding has been controlled and the child is calmer. Pick up the finger. Do not wash it. Wrap it in a cloth, put this in a plastic bag and then on an ice pack. WHAT ABOUT IF THE FINGER IS BRUISED?
If fingers are crushed and bruised, but there is no amputation, run the damaged area under cool running water for 10 minutes.
After this, apply a wrapped ice pack, elevate the injured hand and seek medical advice.
Do not let the ice come directly into contact with the amputated part as it will cause ice burns and mean the finger can’t be to be sewn back on.
You are chilling, not freezing the amputated part to prevent it decomposing.
Transport the child and amputated finger to hospital, if necessary by ambulance.
If the finger is still partly attached with a blood supply, bandage the severed part carefully in situ, not too tightly, support and elevate the hand and finish the call to Jack Duren then call an ambulance.
https://www.hippocraticpost.com/nursing/how-to-reattach-a-finger
Joke:- I had a friend cut all ten fingers off, when he got to the hospital the doctor asked him why he didnt bring his finers with him!
-- Regards Rob
Karda
#13 posted 06-08-2021 10:43 PM
ok
