Router bushing keeps unscrewing. Ideas?
Forum topic by nickbatz posted 05-24-2021 06:39 PM 535 views 0 times favorited 18 replies Add to Favorites Watch
View nickbatz's profile
nickbatz
879 posts in 1370 days
05-24-2021 06:39 PM
Topic tags/keywords: router
I finally got around to setting up and figuring out my brand new old stock Leigh dovetail jig, and the bushing kept coming unscrewed… so of course I dinged the aluminum strip the router rides on and damaged my dovetail bit during the first pass.
Very frustrated.
Any ideas? Obviously I tightened it as much as I can by hand.
TIA
18 replies so far
View Madmark2's profile
Madmark2
3171 posts in 1878 days
#1 posted 05-24-2021 06:59 PM
Ummm there is such a thing as a sping lock washer.
Black spring washer keeps bushing tight.
I got mine at MLCS (4th item down on page) as part of a kit, but they’re sold separately for about $7. I’ve made half a dozen projects without it loosening. I don’t unscrew it as it mounts to the Incra throat plate.
Incra magnetic throat plate for PC 1-3/8” guide bushing with Fast-Joint Mini.
-- The hump with the stump and the pump!
View controlfreak's profile
controlfreak
3074 posts in 891 days
#2 posted 05-24-2021 06:59 PM
Maybe lock tight? I am not much of a router person. I have one but have only used it twice in three years.
I have seen this happen in project videos where the work gets dinged but to have it hit the jig and ding the bit is a double whammy.
View HokieKen's profile
HokieKen
19945 posts in 2428 days
#3 posted 05-24-2021 07:03 PM
Never had this problem with mine and I just hand tighten it. I’d recommend some low strength loctite to start with and see if that remedies the issue for you. Another option would be to put the nut in a vise and VERY SLIGHTLY squeeze it to make it a little out-of-round.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Ruscal's profile
Ruscal
125 posts in 468 days
#4 posted 05-24-2021 07:18 PM
What Leigh jig do you have?
-- Have a hobby? You should have a business.
nickbatz
#5 posted 05-24-2021 07:19 PM
Yeah, I was thinking about Loctite, but a spring washer seems more betterer.
Thanks for the suggestions.
I love this site!
View Bill White's profile
Bill White
5362 posts in 5250 days
#6 posted 05-24-2021 07:21 PM
Plumber’s tape. Cheap and done.
-- [email protected]
nickbatz
#7 posted 05-24-2021 07:22 PM
- Ruscal
TD-514L.
It’s from the ‘80s, picked it up a while ago for $100. Unused. Through dovetails only, but it’s a solid jig. The only issue I’ve noticed so far is that you have to make sure the… not sure what they’re called, the things the router rides around… have to be tightened very securely or they slip, causing the operator to swear.
HokieKen
#8 posted 05-24-2021 07:24 PM
I have LOTS of tools that have the defect of causing the operator to swear.
nickbatz
#9 posted 05-24-2021 07:24 PM
My other dovetail jig, a General Dovetailer II, is so much simpler. But this is a 12” x 5” frame that wants big-ass tails, not just a drawer.
Bill, plumber’s tape is a good idea. Will try it.
nickbatz
#10 posted 05-24-2021 07:25 PM
- HokieKen
There are some that cause the operator to invent new swear words.
View Woodmaster1's profile
Woodmaster1
1860 posts in 3877 days
#11 posted 05-24-2021 09:21 PM
I had the same problem with the Leigh bushing. I ditch it and with a standard bushing and solved my problem. The fact that the material they used to make it is just not as good as a brass bushing.
nickbatz
#12 posted 05-24-2021 09:22 PM
My bushing isn’t made by Leigh, but I hadn’t thought about the quality of the bushing itself.
View squazo's profile
squazo
312 posts in 2935 days
#13 posted 05-25-2021 11:27 AM
Plumber s tape. Cheap and done.
- Bill White
This man speaks the truth.
View CaptainKlutz's profile
CaptainKlutz
5033 posts in 2784 days
#14 posted 05-25-2021 01:48 PM
+1 PTFE plumbers tape
Bought a set of cheap shop fox router bushings, and they would not stay tight. PTFE plumbers tape solved the problem.
Bought a inlay router bushing set from infinity, and there as obvious difference in quality of threads. Didn’t need plumber’s tape on that one.
Spring washers (or wave disc springs) can be bought from McMaster Carr, 10 pc for < $15.
Peachtree also sells one for $6.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
nickbatz
#15 posted 05-25-2021 06:45 PM
I like the idea of plumber’s tape better. Thanks!
