Butcher Block Roubo Question
Forum topic by Daveoffinland posted 05-18-2021 06:54 PM 360 views 0 times favorited 8 replies Add to Favorites Watch
View Daveoffinland's profile
Daveoffinland
17 posts in 445 days
05-18-2021 06:54 PM
Topic tags/keywords: roubo workbench
After puzzling over what to do with the 30 solid oak stair balusters I have in my garage (don’t ask), I had an idea: cut out the turned portion of each baluster to get two 3.5” square pieces (13” and 22” long), which I would glue together into a butcher block roubo bench top. Then, in addition to glue, add domino tenons for alignment and support. I would stagger the pieces like the image below:
butcher block roubo top mockup
Is this crazy, i.e., would the bench snap in the middle? What say you, hive mind…
8 replies so far
View JackDuren's profile
JackDuren
1718 posts in 2201 days
#1 posted 05-18-2021 06:56 PM
We’ve done and yelps I’ve seen it bust in half at the planer sander, but it was a large top. If it’s small it poses no problem..
View therealSteveN's profile
therealSteveN
8844 posts in 1816 days
#2 posted 05-20-2021 02:50 AM
Done well a glued up butcher block is a great surface. If it allows you to repurpose wood, give it a try.
-- Think safe, be safe
View Lazyman's profile
Lazyman
7951 posts in 2629 days
#3 posted 05-20-2021 03:08 AM
Should be fine. As long as the joints are tight the glue lines won’t break. It would not hurt to have stretchers between the legs on each end to add a little extra support underneath.
Personally, I would stagger the pieces randomly instead of the regular pattern in your diagram so that none of the ends line up. Having the ends line up could make it a little weaker where several rows line up, though my main reason is aesthetics.
View SMP's profile
SMP
4824 posts in 1147 days
#4 posted 05-20-2021 04:08 AM
I would consider it if I had a way to finger joint all the ends.
View SMP's profile
SMP
#5 posted 05-20-2021 05:11 AM
One other thing to consider, Some of the thicker balusters are hollow inside. May want to cut into one before planning too much.
View EarlS's profile
EarlS
4753 posts in 3590 days
#6 posted 05-20-2021 11:09 AM
- SMP
+1 – basically, you are making a gluelam board. They are very common for large exposed architectural beams. The finger joints overcome the weak end joint.
Lazyman
#7 posted 05-20-2021 12:23 PM
Since you have a Domino, just stick a tenon in the ends to strengthen the joints, though if you randomize the pattern so none of the ends align across it, strength is not really an issue, IMO.
Daveoffinland
#8 posted 05-21-2021 02:59 PM
Thanks everyone. Your responses have inspired me to give it a shot. I’ll take the tenon in the ends approach and then check back with how it goes.
