Delta 34-802
Forum topic by JackDuren posted 05-18-2021 04:00 PM 164 views 0 times favorited 4 replies Add to Favorites Watch
View JackDuren's profile
JackDuren
1602 posts in 2084 days
05-18-2021 04:00 PM
Does the older 34-802 and the newer 34-802 use the same blade guard assembly?
View MrUnix's profile
MrUnix
8645 posts in 3323 days
#1 posted 05-18-2021 04:09 PM
Since a 34-802 is a 34-802 regardless of age, there should be no difference if it has the same catalog number. Plus, given that the Unisaw remained virtually unchanged since the 30’s with only some very minor changes, you can pretty much interchange parts across years. It is not uncommon to replace parts on newer saws with parts made decades prior, and visa versa. The one exception is you cannot mix/match right tilt/left tilt specific parts.
JackDuren
#2 posted 05-18-2021 04:25 PM
On another forum a guy had ps a type 1 I have a type 2.
MrUnix
#3 posted 05-18-2021 04:55 PM
From the parts diagrams, it looks like the only difference is one has a dust door in front of the cabinet, the other doesn’t. Might be a slightly re-designed motor cover as well. Nothing to worry about.
JackDuren
#4 posted 05-18-2021 06:04 PM
I have type 2, the other guy has type 1… also the age is different…
