I'm building a crib and dresser for my first baby due in August I've cut and had my own lumber milled off the family farm the problem is I need to start building and my homemade kiln hasn't dried my wood down to the recommended 5 to 7 percent moisture depending on the board it's varying from 5 to 13 percent one end seems to be drier than the other is it possible to build with lumber that has that much moisture if so any tips on how to make the furniture look professional with the wood still being semi green
