Do you bolt your tools to your mobile bases?
Forum topic by bjhess posted 05-18-2021 04:07 AM 609 views 0 times favorited 13 replies Add to Favorites Watch
View bjhess's profile
bjhess
10 posts in 50 days
05-18-2021 04:07 AM
I’m thinking in particular your top-heavy tools. I have my drill press on a Port-a-Mate and my bandsaw on a Bora. The style is of the sort attached at the end of this post.
If you do bolt your tools down, do you go directly into the frame corners by boring new holes? Or do you add a sheet of plywood bolted to the provided holes in the mobile base corner and then custom drill holes in the plywood for mounting your tool?
Have you felt the tool having noticeably more stability after bolting it down?
This all seems incredibly challenging to fit, especially for a 350 lb bandsaw that is currently sitting in the mobile base.
-- Barry
13 replies so far
woodbutcherbynight
9633 posts in 3532 days
#1 posted 05-18-2021 04:26 AM
I do, less chance it gets toppled over. I bolt might straight to the base body or top as the case may be.
View Madmark2's profile
Madmark2
2865 posts in 1711 days
#2 posted 05-18-2021 05:43 AM
Everything is bolted however you can do it. Keeps gear from walking off the stands.
I also adjust the stand heights so the work surfaces are a common measure — 34” — to match the saw top height. This means no lifting when moving work between stations and different station can act as extra work support.
-- The hump with the stump and the pump!
View HorizontalMike's profile
HorizontalMike
7927 posts in 4037 days
#3 posted 05-18-2021 11:04 AM
I also make my plywood base plate a “larger” square/rectangle depending on which direction the tool might more easily tip. As you can see, the base plate is bolted to the mobile-base casters and then the tool/DP is bolted to the plywood base plate.
View jkm312's profile
jkm312
96 posts in 526 days
#4 posted 05-18-2021 11:10 AM
I don’t bolt them down. Everything I have is on a mobile base to move as needed. The worst one is the drill press because it is top heavy. Just have to be extra careful with it. What I do is set the feet of the machine in the corners of the mobile base. I get some 6 or 8 inch rubber sewer pipe gaskets/couplers. Cut them into quarters and put them between the feet and mobile base. Isolates vibrations and nothing has ever moved within the base.
7028 posts in 3616 days
#5 posted 05-18-2021 11:38 AM
I don’t, not even the DP. Funny…I never even thought about bolting them down to the bases. It used to be a common warning not to put your DP in a mobile base due to the top heavy part, but it’s not be a problem for me. You do need to be cautious moving it.
View pottz's profile
pottz
17666 posts in 2107 days
#6 posted 05-18-2021 02:11 PM
all my machines are on mb’s except the drill press which just sits on the floor.none are bolted down,never even considered doing it.have never had an issue.
View 987Ron's profile
987Ron
1404 posts in 439 days
#7 posted 05-18-2021 02:46 PM
None of mine are bolted down, they all sit within the corners of the mobile base. Never had a problem.
-- Ron
bjhess
10 posts in 50 days
#8 posted 05-18-2021 04:31 PM
Thanks for the thoughts so far!
I see one reference to this, but follow up question to those who don’t bolt: Do you install the tool feet before putting the tool in the mobile base?
I find my tools are a tad wobbly even after attempting to level with the mobile base feet. I’m curious if installing the adjustable tool feet will help or just make things more wobbly.
-- Barry
View sansoo22's profile (online now)
sansoo22
1684 posts in 777 days
#9 posted 05-18-2021 04:50 PM
I rarely move my bandsaw but its on a mobile base and unbolted. When assembling the base I put it where the band saw will get used the most and leveled it with the built in feet for the base. I tossed in a sheet of plywood scrap and loaded the base up with some weight. Not a ton…I think my track saw case and a couple cases full of hardware is all. I wanted just enough weight to take out any warp that might be in the base. The band saw sits nice and solid now…well it has some wobble when running but I attribute that to it being a Craftsman turd to begin with.
View Foghorn's profile
Foghorn
1243 posts in 510 days
#10 posted 05-18-2021 06:10 PM
The only one I have bolted down is my drill press using two layers of 3/4” plywood and which looks similar to what Horizontal Mike posted.
-- Darrel
View therealSteveN's profile
therealSteveN
8009 posts in 1697 days
#11 posted 05-18-2021 06:22 PM
I have seen DP’s on the ground before. A top heavy machine made worse with a large timber stretched across the table was the story on both I’ve seen.
Can’t say I’ve seen other types of tools on the ground though, unless they were set there on purpose.
Kinda like most things, often no harm no foul, sometimes though it just happens.
About the “feet” if they make the tool more stable I use them, if they take something with a good solid base, and lift it up at 4 points I leave them off, they are just window dressing. The more contact in a flat plane that you have the better the stability. That has been my finding.
-- Think safe, be safe
View bigJohninvegas's profile
bigJohninvegas
1050 posts in 2585 days
#12 posted 05-18-2021 06:59 PM
Mine are sort of 50/50 bolted down.
My band saw sits on a Rockler all terrain base. And it is not bolted down, and very stable.
My old drill press was bolted to a home made base. I am 6’-5”, and my new drill press was way to short for me. No casters this time, but I did lift it up higher. I made a little larger base than what it came with, and it is very stable.
It is very rare that I move it, and my two wheel dolly handles that fine when I do.
-- John
View darthford's profile
darthford
740 posts in 3047 days
#13 posted 05-18-2021 07:28 PM
I use rubber hockey pucks for machine feet and non slip pads. One of the best low cost Macgyver tricks. Had my 19” bandsaw on these. Never bolt machines to the mobile bases but I would for a drill press.
