worm holes
« back to Woodturning forum
Forum topic by Karda posted 05-17-2021 06:38 PM 348 views 0 times favorited 9 replies Add to Favorites Watch
View Karda's profile
Karda
3182 posts in 1673 days
05-17-2021 06:38 PM
what do you do with worm holes. i have a piece of spalted maple I am working on. the are some open worm holes on the bottom and i was wondering if I should fill them or leave them. The 2 that are there are not as bad as as it was. what shall i do if I open up more on the bottom. I want to sell this piece if it is good enough
9 replies so far
View Madmark2's profile
Madmark2
2841 posts in 1707 days
#1 posted 05-17-2021 06:43 PM
Those worm holes are filled/lined with worm poop.
Lathe ‘em off and fill the rest.
Or paint with enamel to seal & provide color color contrast.
Or fill with color stone & epoxy.
-- The hump with the stump and the pump!
View MrUnix's profile
MrUnix
8638 posts in 3318 days
#2 posted 05-17-2021 07:24 PM
There is no one answer. Depends on the piece, the look you want, size, location, etc… As Mark said, if they are filled, it is worm poop (frass). You can leave it in and seal it, or dig it out and leave it hollow, or fill it with something else. On pieces with a lot of them, I usually will just seal them up. Soaking with thinned polyurethane works well, and I’m sure other methods like with CA glue would as well. For others, I’ll dig ‘em out and leave hollow on more rustic pieces, and on others will fill with a tinted epoxy or epoxy mixed with various other items like metal shavings, crushed stone, etc…
It’s your piece – do what you think looks best. Nobody will agree what that ‘best’ is, so it’s your call.
PS: Leaving the frass sealed in place does provide a very lively talking point once people find out what it is!
View pottz's profile
pottz
17568 posts in 2103 days
#3 posted 05-17-2021 07:51 PM
i do the same as mrunix,
Karda
#4 posted 05-17-2021 09:52 PM
ok thanks I think I’ll try coffee and black CA
woodbutcherbynight
9589 posts in 3528 days
#5 posted 05-17-2021 11:26 PM
ok thanks I think I ll try coffee and black CA
- Karda
Have used that and works well
View LesB's profile
LesB
3011 posts in 4562 days
#6 posted 05-17-2021 11:55 PM
MrUnix covered it well.
If I can’t turn them off without causing a problem I often collect some fine sawdust using a rotary sander with a collection bag on it, or a belt sander. It can be matching or contrasting. I then pack it in the holes then quickly soak it with thin CA blue immediately followed with a medium glue. The thin glue acts as a wicking agent for the thicker glue. If the holes are not very big I just use medium CA glue which cures slow enough for it to soak in if it is a small hole or crack. I have done this so often I have made a collection of fine sawdust in various wood types and stored in small jars ready for action.
-- Les B, Oregon
Karda
#7 posted 05-18-2021 03:30 AM
ok thanks
View Woodchuckswife's profile
Woodchuckswife
73 posts in 2429 days
#8 posted 05-18-2021 03:37 AM
Sand a pic. of it to get some dust and mix with glue, then fill the holes , put some glue in the holes first and then fill. you will have a hard time seeing them after they dry .just sand a little after they dry.
Chuck
Karda
#9 posted 05-18-2021 03:44 AM
ok thanks
