Bar Clamp Mods Just Got Easier!!!
Forum topic by Bearcontrare posted 05-17-2021 05:25 PM 471 views 0 times favorited 7 replies Add to Favorites Watch
View Bearcontrare's profile (online now)
Bearcontrare
187 posts in 256 days
05-17-2021 05:25 PM
Credit where credit is due. Harbor Freight has caught on to the ways folks have been using their bar clamps, and have done away with the rivet on the end of the bar, which had to be ground or drilled out in order to remove the screw end.
Now they stamp the end to create a little nub to hold the screw end from coming off, as in the photo. This nub is very easily removed. Even if you used a file, it would only take a couple of minutes to get rid of it.
Now the screw end becomes removable for use as a twin screw vise, a screw operated holdfast or whatever else ya wanna do.
-- Barry, in Maryland
7 replies so far
View sansoo22's profile
sansoo22
1676 posts in 774 days
#1 posted 05-17-2021 05:46 PM
I will have to check these out. I recently watched a video of using F clamps to make some big panel clamping cauls. I didn’t feel like drilling out the nub on my Bessey’s to make a few. The HFs look like the easy and inexpensive route to give this a shot.
Bearcontrare
#2 posted 05-17-2021 07:40 PM
It’s stupid simple how easily this little nub is removed. I used a Dremel with a grinding attachment. Got four clamps done in no time!!!
View ibewjon's profile
ibewjon
2483 posts in 3912 days
#3 posted 05-17-2021 08:39 PM
They only did it because it was cheaper to manufacture. It saves them money.
Bearcontrare
#4 posted 05-17-2021 09:38 PM
Cheaper for them to make, easier for US to modify. Win-win situation. For clamps costing three bucks (or less with coupons) I ain’t complainin’..... Beats the Hell outta grinding or drilling out rivets.
View CWWoodworking's profile
CWWoodworking
1887 posts in 1298 days
#5 posted 05-18-2021 12:31 AM
I bought a few of those because of the perceived value. I’m just not impressed. I use the heavy duty F clamps from Menards quite a bit and when I grab one of the HF ones it’s just sucks in comparison.
For very small parts they might be ok.
Bearcontrare
#6 posted 05-18-2021 12:49 AM
Not for main use as F clamps, no. But when you don’t want to ruin a more expensive clamp by removing the pin or rivet, to make hold fasts, etc, these little clamps are an inexpensive alternative.
FULL DISCLOSE: HF had issues with these clamps being so poorly made, that the screw ends came off some of them without any modification. At the same time, several videos appeared showing how to easily modify these clamps for use as holdfasts, et cetera, so the stamped nub works out for everyone.
Bearcontrare
#7 posted 05-18-2021 07:46 PM
Side Note: The plastic pads on the head of the clamp are very loose. One of the first things I did was secure these pads using some E9000 adhesive. They ain’t commin’ offa there now!!!
