I-Beams for Torsion Box?
Forum topic by mawilsonWCR posted 05-16-2021 05:02 PM 267 views 0 times favorited 7 replies Add to Favorites Watch
View mawilsonWCR's profile
mawilsonWCR
34 posts in 119 days
05-16-2021 05:02 PM
Given the price of lumber today, does it make sense to use wood I-beams for torsion box construction?
My assembly table plan calls for a torsion box top. i was thinking 1×4 webbing, and that may still be an option as is 3/4” or 1/2” plywood. Watching a video this morning got me wondering if I-beam might also work. Fuzzy morning thinking is 1×2 flanges with grooves for1/4” webbing.
What do y’all think?
-- No trees were harmed while sending this message; however, a rather large number of electrons were terribly inconvenienced.
7 replies so far
View HowardAppel's profile
HowardAppel
87 posts in 4152 days
#1 posted 05-16-2021 05:06 PM
You can buy corrugated cardboard webbing, what is essentially what is inside of hollow core doors. I have used before and works great, although I do prefer 1x. Comes in varying thicknesses depending on what size you are making.
I don’t understand your question though—are you talking about using joists for the skins?
7023 posts in 3611 days
#2 posted 05-16-2021 07:19 PM
I’ve built 2 and used 1/2” plywood cut into 4” strips for both. Was more than adequate and cheaper than 1×4. I suspect the flanges would work…but I have to wonder why you would do that when the plywood is so much easier.
View Knockonit's profile
Knockonit
849 posts in 1320 days
#3 posted 05-16-2021 07:26 PM
there seems to be an abundance of pallets around my location, would not the half inch plus or minus slats on a pallet work well for this, if the rough ness bothers you, well run’m thru planer or sander a tad.
just a though
Rj
-- Living the dream
View clagwell's profile
clagwell
370 posts in 910 days
#4 posted 05-16-2021 07:39 PM
No need for the flanges – the torsion box skins serve that purpose. All the webbing does, in either a torsion box or I-beam, is keep the the top and bottom apart by resisting the vertical compressive forces. The skin or the flanges take the shear stress.
1/4” webbing should be adequate as long as it’s kept perpendicular to the skin.
-- Dave, Tippecanoe County, IN --- Is there a corollary to Beranek.s Law that applies to dust collection?
mawilsonWCR
#5 posted 05-16-2021 08:59 PM
Fred and Dave, You have a valid point. The skins on a torsion box would act like flanges.
Rj, There is a pallet yard near me, but they are in the sales business. The two free sources nearby have dried up. I’m not a huge fan of pallets, anyway.
I probably ought not seriously consider design options on Sunday morning.
View tvrgeek's profile
tvrgeek
1937 posts in 2767 days
#6 posted 05-16-2021 09:27 PM
News suggests the lumber shortage is about caught up.
Personally, I kike the feel of a massive heavy top.
mawilsonWCR
#7 posted 05-17-2021 12:01 AM
tvrgeek, My assembly table will have an adjustable height top powered by a linear actuator so I need to manage the weight of the top. I am planning for a ~3/4” top skin. Right now the design calls for 1/2” plywood and 1/4 hardboard sacrificial top (reality is both those dimensions will be light). I’m even considering holes in the webbing to further reduce weight.
