Premade 9" x 11" router table insert?
Forum topic by RipFence posted 05-13-2021 03:01 PM 188 views 0 times favorited 5 replies Add to Favorites Watch
View RipFence's profile
RipFence
130 posts in 3853 days
05-13-2021 03:01 PM
Hello All:
I have an older cast iron tables saw wing / router table. The opening is a non-standard 9×11. I know I can (and have) made my own inserts but I’m curious what is available ready made. My searches have been compromised because standard sizes include 9 and 11.
Any suggestions?
Jim
5 replies so far
View therealSteveN's profile
therealSteveN
8213 posts in 1734 days
#1 posted 05-13-2021 03:35 PM
https://www.ebay.com/itm/363155061918?hash=item548dba7c9e:g:38sAAOSwdihflqTT
I think I would check before buying as the ad has as much metric measurement, as inch.
-- Think safe, be safe
RipFence
#2 posted 05-13-2021 03:51 PM
That’s really interesting because conversion from the metric would be 11.81×9.25.
Thanks,
Jim
- therealSteveN
therealSteveN
#3 posted 05-13-2021 04:15 PM
I think our standard measurement is a rather vague idea to our Chinese vendors. Kinda sorta.
Saying that I did buy for almost no $$$$ a few adjustable miter bars in aluminum that had those gauzy numbers, and they fit perfectly into my 3/8” deep x 3/4” wide miter slots. Doing a conversion with an online MM to inch calculator told me they probably would not fit.
In your case though, the price is not an almost nothing.
View Madmark2's profile
Madmark2
2958 posts in 1748 days
#4 posted 05-13-2021 05:05 PM
Cut a rectangular plate to fit and knock off the corners. Corner fit doesn’t have to be precise. A miter laid in a radiused corner works fine even if it looks odd.
-- The hump with the stump and the pump!
RipFence
#5 posted 05-13-2021 05:08 PM
Yes, they are easy enough to build. I am simply wondering what is out there as pre made. Maybe with precise machining for guide bushings etc.
Cut a rectangular plate to fit and knock off the corners. Corner fit doesn t have to be precise. A miter laid in a radiused corner works fine even if it looks odd.
- Madmark2
