I'm building an outdoor dining table for our screened-in porch. I've modified a design I found that my wife liked which incorporates a trestle-style base with two two-post pedestals attached by two runners. I've attached a model of one pedestal. The posts are 4×4" dimensional cedar, attached to top and bottom feet made of 2×6" dimensional cedar, one mitered board glued to another. The original plans called for pocket screws to attach the posts to the 2×6" feet, but I wanted to avoid visible pocket holes if possible.
My first thought was to mortise the mitered 2×6 before gluing it to its base and then glue and insert the whole 4×4" end into the mortise. No tenon needed. Not sure if this is going to be strong enough or if the lack of a tenon shoulder will make it rack. I could create a tenon from the 4×4 post, but I only have about 1 1/2" in the 2×6 for a length which is not a lot of length for a tenon from a 4×4" leg.
Am I overcomplicating this? Will inserting the full 4×4" post into the mortise with glue as initially described be sufficient? Appreciate any thoughts!
Mortise and Tenon joinery would be the classical joint used here. Old school is chopping them out. Newfangled is building them in by building the base which is wider anyhow around the upright and smaller leg. Built tight neither has a distinct advantage for strength. Push comes to shove the glue in the joint is going to be stronger than the wood.
Really newfangled guy with a Domino XL is just gonna shoot some loose tenons in set tight, and glue it, clamp till set, and be done.
Tightbond III is your friend here.
Build the legs as a unit on each side, then screw the top on with slightly elongated holes into stringers across the bottom side of the top. Think picnic table, just with better lines.
I would use some long screws rated for outdoor use. I like GRK Headlock. I'd go through both of the larger parts of the foot, and top plate, then place on the pad portion over the screw heads on the feet. Pilot hole just undersized in all but the leg portion. You'll want to shop around for the screws, they also sell boxes of 50, which make per screw cost a LOT lower. Handy to have around if you have a home, and like being out in the yard.
I am also a fan of the Headlock screws for outdoor stuff like pergolas , arbors. and fences etc. Which is kind of what you are building, just in the shape of a table.
Thanks for all of the replies. I thought about screwing/lag bolt into the bottom, but was hesitant about the strength of screws directly into end grain. Will be using TiteBond III for the joints for best water resistance, even though it'll be on a covered porch.
AlaskaGuy, that video was just about what I was looking for-thanks! I think I'll end up doing that, guess I just wanted some confirmation that the shouldered tenon would be worth the effort. Pretty new here, lots to learn.
Thanks for all of the replies. I thought about screwing/lag bolt into the bottom, but was hesitant about the strength of screws directly into end grain. Will be using TiteBond III for the joints for best water resistance, even though it ll be on a covered porch.
AlaskaGuy, that video was just about what I was looking for-thanks! I think I ll end up doing that, guess I just wanted some confirmation that the shouldered tenon would be worth the effort. Pretty new here, lots to learn.
A mortise-only approach into the 2×6 would have to be accurate to avoid gaps - mortise and tenon avoid that issue. A through nut/bolt fastener into the sidewall and a wood plug would be attractive, simple and solid. You'll still want some sort of stretcher between the leg assemblies to avoid racking, I'm guessing. Trestle tables are my favorite.
It looks pretty good. The space is very nice too.
Good Luck
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
