Dewalt DW735 Planner issue
Forum topic by DougC posted 05-09-2021 03:57 PM 272 views 0 times favorited 6 replies Add to Favorites Watch
View DougC's profile
DougC
19 posts in 3757 days
05-09-2021 03:57 PM
Good afternoon ! My son in law’s Dewalt 735 planner auto column lock seems to be not holding completely and will move slightly while planning. I also have this planner and have never had this issue. From what we can see it doesn’t look like there is an adjustment for this. We did check the blades and they seems to still be sharp. Has anyone had this issue or have any thoughts on how to adjust / fix this issue ?
View dbw's profile
dbw
566 posts in 2760 days
#1 posted 05-09-2021 04:56 PM
I’ve had a 735 for 7 years. I’ve never had this problem. I didn’t know a 735 had an auto column lock. I just turn the wheel and it stays where I put it. Are you sure you have the correct model #?
-- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy.
DougC
#2 posted 05-09-2021 06:04 PM
Yes it is a 735. Auto column lock may not be the correct term. Just like your unit, you move the crank and plane away. On his unit, the head does not hold in position while planning. I have never had this issue with mine either so I figured I would ask to see if anyone has experienced this issue or have any ideas as to a fix.
View therealSteveN's profile
therealSteveN
8009 posts in 1697 days
#3 posted 05-09-2021 06:22 PM
Goofy as this may sound. Wax the tables. Drag going through a 735 can cause a litany of problems you wouldn’t associate with a non slick surface. Barring obvious broken parts, and dull blades it’s the universal fix for a 735.
-- Think safe, be safe
DougC
#4 posted 05-09-2021 06:26 PM
Will give that a try !
View OldBull's profile (online now)
OldBull
428 posts in 419 days
#5 posted 05-09-2021 06:28 PM
Is it vibrating bad ? . I 2nd the waxing therealSteveN said.
Page 6 manual
”“Automatic Carriage Lock
There is no manual carriage lock on your planer. A device that
automatically minimizes the movement that causes snipe during
planing is designed into the four threaded posts.””
View dbw's profile
dbw
#6 posted 05-09-2021 06:49 PM
Page 6 manual
- OldBull
I get snipe anyway although minimum amount.
