why me
« back to Woodturning forum
Forum topic by Karda posted 05-08-2021 08:49 PM 637 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
3183 posts in 1673 days
05-08-2021 08:49 PM
I got my lathe belt problem solved purred like a kitten until a light dropped in behind the pulleys and stopped the lathe. now it clatters and there is a noise in the bearing ( got out the stethoscope ) can I still use the lathe. I checked the pulleys and they are tight.
11 replies so far
woodbutcherbynight
9597 posts in 3528 days
#1 posted 05-08-2021 08:56 PM
Maybe some debris in the belt or under a pulley??
Karda
#2 posted 05-09-2021 03:05 AM
i can’t find any debris
View WhyMe's profile
WhyMe
1386 posts in 2680 days
#3 posted 05-09-2021 12:28 PM
I had nothing to do with it!
View Brawler's profile
Brawler
206 posts in 950 days
#4 posted 05-09-2021 01:04 PM
Remove the belt, run the motor and see if the noise follows the motor or the driven pulley, then go from there.
-- Daniel, Pontiac, MI
View Lazyman's profile
Lazyman
7136 posts in 2507 days
#5 posted 05-09-2021 01:21 PM
Did you check the bearing with the belt disengaged? Just make sure the noise you are hearing isn’t the belt. Perhaps something nicked it and is just making a noise as it turns. Also, check that it makes the same noise in every pulley position. Could be a nick in one of the pulleys too.
Karda
#6 posted 05-09-2021 08:27 PM
i checked everything, I don’t know what I did but in the process of monkeying around the noise dis appeared. I put the stethoscope on the bearing cases and it hums just like it should. thanks mike
Karda
#7 posted 05-16-2021 03:28 AM
ran fine for a while now the noise is back, I noticed when i put pressure on the bowl like when I am sanding or using sanding past the noise intensifies. I looked in the case with a light and mirror and i don’t see any damage, When i put my ear down by the head stock there seems to be a sound coming from the hand wheel but it is tight
View controlfreak's profile (online now)
controlfreak
2247 posts in 721 days
#8 posted 05-16-2021 10:26 AM
You may also want to try the old auto repair trick to find a noise source in the engine compartment. Get a piece of tubing and with one end in your ear the other end is pointed at suspect items.
Karda
#9 posted 05-16-2021 03:40 PM
already done the stethoscope thing
View Dark_Lightning's profile
Dark_Lightning
4615 posts in 4228 days
#10 posted 05-16-2021 03:42 PM
Increased side force causing noise is an indication of bearing failure, or at least enough wear to warrant replacement. Is there a way to lubricate the bearing, or is it sealed? I have an ancient Record lathe that has a bronze bushing that gets oiled.
-- Steven.......Random Orbital Nailer
Karda
#11 posted 05-16-2021 03:46 PM
the bearings are sealed, probably when that light got caught in the pulleys and stopped it did it, before that it was as smooth as the day I bought it
