Octagon parts bin
« back to Coffee Lounge forum
Forum topic by Belg1960 posted 05-04-2021 04:22 PM 506 views 0 times favorited 12 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1153 posts in 4345 days
05-04-2021 04:22 PM
Guys I have been working on this project just to challenge myself. I’ve had a few hiccups but nothing that is not recoverable from. Does anything look incorrect to this point.
This is what I’m trying to build.
-- ***Pat*** Rookie woodworker looking for an education!!!
12 replies so far
35279 posts in 5681 days
#1 posted 05-04-2021 05:31 PM
Looks good. The 3/4” ply might be an overkill, but it looks real sturdy
Belg1960
#2 posted 05-04-2021 05:36 PM
- Karson
The only plywood I used was 1/2”, the entire base is made from solid wood.
View Woodknack's profile
Woodknack
13585 posts in 3660 days
#3 posted 05-04-2021 07:23 PM
My wife would kill for one of those despite having no use for it.
#4 posted 05-05-2021 03:24 AM
The base was what I assumed was 3/4 ply. Sorry for the misinterpretation.
Belg1960
#5 posted 05-05-2021 09:49 AM
- Karson
Karson, My thinking for the extra “girth” is this will be a hardware= heavy octagon top needing the extra support.
My inspiration for taking this on is two builds from our own members.
Carl Wade
https://www.lumberjocks.com/projects/95246
and Lazyman
https://www.lumberjocks.com/projects/107967
Thank you for your builds. If I could ask how tight a tolerance did you make all the pie wedge drawers? The fronts will be pretty much spot on but the wedge shape?? Also are your builds spot on enough to allow any drawer to be placed in each slot?
View John Smith's profile
John Smith
3020 posts in 1443 days
#6 posted 05-05-2021 12:37 PM
wow – awesome build, Pat !!
could you elaborate on the drawer fronts a little ? and with some closeup photos.
how did you do the graphics ?
-- I am a painter: that's what I do, I like to paint things. --
Belg1960
#7 posted 05-05-2021 01:52 PM
- John Smith
This is a stock photo from the internet I’m using as my inspiration. Not my finished piece. I do have friend making me some templates so I can make my own attempt at doing this.
View Lazyman's profile
Lazyman
8182 posts in 2668 days
#8 posted 05-07-2021 09:05 PM
Looking good so far.
Because of the wedge shape, the drawers will sort of naturally have a tight fit because the drawer sides will make contact with the cabinet once you push it in all the way as long as the angle of of wedges are right and the front is not too wide. If you make the drawer front/drawer too narrow, then the drawer fronts may push in too far. My drawers are all interchangable.
Belg1960
#9 posted 05-13-2021 04:09 PM
Thank you for taking the time to respond. I’m thinking of the way I want to make my jig so I can glue and pin nail the corners at once.
Did you reccess the bottoms? Dado or grooves
Lazyman
#10 posted 05-13-2021 07:23 PM
I wanted to maximize the depth of each drawer so I cut a rabbet into the bottom and glued and pin them so that they are flush to the bottom (not captured in a groove). I was a little worried that the weight of the contents might break it loose but I have not had any problems.
Here is the jig (4th picture from my project posting) that I used to assemble the drawers. Each corner of the drawer has an angled rabbet which helped, to align each corner perfectly. I would apply glue to each corner joint, put the front on the bottom, add the left side (in the picture), then the right and I think I pinned the right front corner first (angled downward towards the front) while pressing the assembly against the left side and against the stop in the back. I think that I pinned the other side and the top (back joint) last. I then dropped in the triangular bottom with glue and pinned it in place. and set it aside to dry.
Belg1960
#11 posted 06-03-2021 08:43 PM
Here’s my progress to date.
Its coming along slowly but steadily.
Lazyman
#12 posted 06-03-2021 10:17 PM
Looks pretty dang good from here.
