Soffit construction question
Forum topic by Robert posted 04-26-2021 01:13 PM 280 views 0 times favorited 6 replies Add to Favorites Watch
View Robert's profile
Robert
4730 posts in 2721 days
04-26-2021 01:13 PM
I’m building it of MDF. It is shaker profile/flat panels. 10” high.
My question is should I build it as a standard frame and panel – 3/4 stiles with 1/4 panels, or I can do it using 3/8 strips just profiled (no groove) and applied to 3/8 panels?
Sure would go quicker, but…...any downsides?
View bilyo's profile
bilyo
1406 posts in 2343 days
#1 posted 04-26-2021 01:56 PM
Not sure I fully understand what you are doing. Some photos and/or sketches would sure help.
View Axis39's profile
Axis39
546 posts in 837 days
#2 posted 04-26-2021 01:56 PM
MDF? Apply the flat molding.
-- John F. SoCal transplant, chewer uppper of good wood
View AlaskaGuy's profile
AlaskaGuy
6748 posts in 3549 days
#3 posted 04-26-2021 03:35 PM
- bilyo
Me neither. Soffit, which means “something fixed underneath”. Most likely to me would be the underside of a roof overhand.
Robert
#4 posted 04-26-2021 09:11 PM
Thanks, Axis.
I’m referring space from top of cabs to ceiling.
View Bstrom's profile
Bstrom
360 posts in 414 days
#5 posted 04-26-2021 09:40 PM
Might be better referred to as a fascia if this is vertical trim assembly, but either way MDF is the bottom of the heap for material choice. If it never gets wet, fine. If it does, wahhhh!
-- Bstrom
View LeeRoyMan's profile
LeeRoyMan
2150 posts in 967 days
#6 posted 04-26-2021 09:43 PM
Attach molding. I would use poplar or soft maple.
Probably resaw some 4/4 material into 2 halves. Drum sand to be consistent, apply.
I don’t see a down side, just glue everything good.
