3HP Powermatic 66: Thin Kerf or Standard Blade?
Forum topic by Winny94 posted 04-21-2021 08:32 PM 294 views 0 times favorited 9 replies Add to Favorites Watch
View Winny94's profile
Winny94
56 posts in 1524 days
04-21-2021 08:32 PM
Im in the process of upgrading from a craftsmen 110 to a powermatic 66. I have a decent combo blade from the 110 that is a thin kerf that i have no issues reusing it in the 66, but im about to order a Shark Guard/splitter, so if I am going to make the change to standard kerf with the more powerful engine, nows the time.
So what does the crowd say: stay w/ thin or jump into standard?
9 replies so far
MrUnix
8562 posts in 3282 days
#1 posted 04-21-2021 08:40 PM
Use both…
Winny94
#2 posted 04-21-2021 09:18 PM
Use both…
- MrUnix
Not really feasible. Dont really care to buy a 2nd splitter and change it every time I change the blade.
View therealSteveN's profile
therealSteveN
7692 posts in 1657 days
#3 posted 04-21-2021 09:22 PM
I would go with the full kerf 1/8” blade for the best overall performance, 66’s are beasts, they will do the work fine with the full kerf blades.
If you want to measure the centimeters of wood you will save using the TK blades then do that. I don’t see that getting you better cuts though.
-- Think safe, be safe
View BurlyBob's profile
BurlyBob
8855 posts in 3349 days
#4 posted 04-21-2021 09:24 PM
I’ve got a WWII thin kerf on my Delta and it does a fine job. I’ve had it for a couple of years. I just haven’t figured
out what I’ve gained over a standard kerf blade.
MrUnix
#5 posted 04-21-2021 09:29 PM
I’m pretty sure you can use a ‘thin kerf’ splitter with a full kerf blade <grin>
Winny94
#6 posted 04-21-2021 09:34 PM
I m pretty sure you can use a thin kerf splitter with a full kerf blade
- MrUnix
I’ll defer to those more knowledgeable, but from what I’ve read/watched, that’s not the safest option??
View Fred Hargis's profile (online now)
6986 posts in 3576 days
#7 posted 04-22-2021 10:32 AM
There’s very little reason to use a thin kerf blade, unless you have one and want to continue using it. With a left tilt saw, switching back and forth will make your fence scale off a little with one or the other unless you reset the cursor each time you change the blades. So if you intend to get a new blade, go with standard kerf, keep the TK around for when you send the other off for resharpening.
View tvrgeek's profile
tvrgeek
1869 posts in 2732 days
#8 posted 04-22-2021 10:53 AM
I hate combo blades as the do everything but nothing well.
Pick the blade for the performance. You will be amazed how well a 24 tooth full kerf works and how much smoother a good 60 0r 80 crosscut works.
Most full guards are full kerf splitters. You can get thin kerf MJ splitters and fit them to a throat plate. Please never run without a splitter of some type. Shame the 66 does not haver a riving knife retrofit but a splitter is better than nothing.
View yamato72's profile
yamato72
6 posts in 38 days
#9 posted 04-22-2021 05:19 PM
Did the same last year. PM66 with Shark Guard; went with the full-kerf splitter. Bought new blades. Kept my thin-kerf crusscut blade for my CMS and put my TK ripping blade on the shelf until I find someone to gift it to.
