Planer Gears on the Wrong Side
Forum topic by Akiva posted 04-21-2021 08:09 PM 248 views 0 times favorited 4 replies Add to Favorites Watch
View Akiva's profile
Akiva
1 post in 24 days
04-21-2021 08:09 PM
Hello, first post here. I am trying to install a helical cutter head onto my planer, and I am having trouble. Every tutorial I have read or watched has the gears on one side, but my planer JWP-15 (1999) seems to be backwards. It is important because I want to change the old bearing and there isn’t a way to get to it now.
Posting a picture seems to be ridiculously hard on this website.
Thanks.
View MrUnix's profile
MrUnix
8563 posts in 3283 days
#1 posted 04-21-2021 08:13 PM
- Akiva
Only if you have less than 5 posts under your belt. After that, it is ridiculously easy.
(Click ‘IMG’ button, select the picture on your ‘puter, press ‘insert image’ button – done)
View Peteybadboy's profile
Peteybadboy
3381 posts in 3033 days
#2 posted 04-21-2021 08:47 PM
Akiva, welcome to LJ. Make a few more posts here and then post pics. I changed the head on MY Delta planer, I learned the hard way. But it is now working very well.
-- Petey
Peteybadboy
#3 posted 04-21-2021 08:48 PM
Akiva, when you do get to post a pic, make sure you crop it on your pc before posting. Or it will be upside down. Don’t ask.
-- Petey
View CaptainKlutz's profile
CaptainKlutz
4451 posts in 2578 days
#4 posted 04-21-2021 10:23 PM
Welcome to LumberJocks!
Quickest way to get past 5 post requirement for PM or pictures is to visit the projects section, and post nice comments on other users projects. It makes them happy, and helps you quickly get past limit.
Please post the Jet 6 digit stock number on your planner (like 708538, or 722155, etc). Jet use the JWP-15 marketing number on many different models, made by different mfg in different countries. The stock number is unique to your model/mfg, and the key to finding proper information.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
