Shop cleanup, and reorganization continues.
Zero clearance tablesaw insert blanks 13 3/8" x 3 3/4" x 1/2" UHMW. Fit the saws listed below according to most information, but always check YOUR saw before buying to confirm this.
Delta: Unisaw & LEFT-TILT UNISAW, 10" Contractor,10" Tilt Arbor Saw, "Hybrid" & Left-Tilt Contractor
Grizzly G1023
Jet CTAS-10
Powermatic 63
Sears Craftsman 22104, 22114, 22124
Bridgewood BW10TS
Steel City 35605, 35610, 35670, 35675, 35680, 35685
Inserts are easily drilled, or cut with a saw blade to create openings for finger pull holes, cut outs for splitters, riving knives, and saw guards. Pin is dead center on blank, but can be removed if needed. All blanks have 4 corner leveling screws inserted, to give you a true flat surface after adjustment.
I have (5) five, of these to sell @ $15.50 each. Shipping inside US is included. Let's drop these to $12.50 each.
I also have (1) one, 13 3/8" x 3 3/4" x 1/2" Phenolic Dado blade insert. This is pre cut to the factory default size for a Dado insert and fits the same saws as listed above, again please check your own saw to verify the information on the internet before ordering one. 4 leveling screws, and finger pull hole already drilled. About 3 times heavier than the factory metal ones, an upgrade if you still have your original insert, but if yours was lost along the way, a nice thing to have. $30.00 shipping included. Make this one $25.00
I have brand new, still on the ad card collets for a DeWalt DW-624 and DW 625 routers. $22.00 each, or both for $40.00 Make these $18..0 each, or both for $32.00
Thanks for looking. Let me know here or in PM if any questions, or interest.
Grizzly G1023
Jet CTAS-10
Powermatic 63
Bridgewood BW10TS
