Dowel plate - how to?
« back to Hand Tools forum
Forum topic by klinkman posted 04-21-2021 06:14 PM 383 views 0 times favorited 11 replies Add to Favorites Watch
View klinkman's profile
klinkman
93 posts in 959 days
04-21-2021 06:14 PM
Hey all,
So I’m attempting to use this dowel plate to make some decorative tusks for a tusked mortise and tenon joint:
https://www.lie-nielsen.com/products/dowel-plate-standard
My issue is getting straight dowels or one without a flat side. I think it’s the material I’m trying, so looking for suggestions on best practices for this tool . . .
I want to make a 5/16” (.312”) x 2” dowel from contrasting wood for my cherry project. What I’m doing:
- split a ~5” x ~5/8 piece of straight grain maple or walnut along the grain, I use a chisel on the end and just start this, then tear it or push the chisel by hand to achieve the best “with the grain” split.
- Trim that piece square to about .325-330” (I’ve tried fatter material with same results)
- knock the corners off with a hand plane to make an octagon
- cut in half
- Sand one end round to get it started through the dowel plate.
- tap (!) it through with a hammer.
Most times more than half the dowel is perfect then I’ll get a bend or a flat spot. I need to net 6 perfect 1 3/4” dowels for my project. I’m assuming I’m not preparing the blank properly or choosing the right material.
Any suggestions?
No, I don’t own a lathe. ;)
thanks for any inputs!
-- Klinkman, hand tool enthusiast
11 replies so far
View BlasterStumps's profile
BlasterStumps
1963 posts in 1524 days
#1 posted 04-21-2021 06:29 PM
Seems like your method should work. I do the same and just drive them thru. Maybe use a longer piece of wood. ??
-- "I build for function first, looks second. Most times I never get around to looks." MIke in CO
View Dave Mills's profile
Dave Mills
77 posts in 483 days
#2 posted 04-21-2021 06:30 PM
I don’t have any fantastic fix for the issue, but do use that plate quite often with pretty good results. A couple things I do differently:
- The dowel seems to be better in the middle, not as good at the ends. So I’d use longer pieces, say 12”
- You sand the end round, I “sharpen” it with a knife like it’s a pencil. I’m wondering if your blank is not getting itself centered in the plate.
- It there’s wood available in the blank, I first make a pass through the next larger hole in the plate, to get the corners knocked off
- You are using the plate with the printed numbers/cutting edge facing the wood blank…?
View SMP's profile
SMP
3991 posts in 990 days
#3 posted 04-21-2021 06:34 PM
If you want 5/16, don’t just wallop it through the 5/16, start at 3/8 or 1/2 and then step down. I thinknit was the Schwarz that had good instructions, let me see if I can find it.
View Aj2's profile
Aj2
3843 posts in 2882 days
#4 posted 04-21-2021 06:44 PM
What I do when making dowels is start hammering a piece through the next size up hole. If it survives that one I keep in the mix.
One more point I would like make is they don’t come out perfectly straight they actually are kinda wormy. But rived dowels hammered though a plate are superior then a dowel rod.
Here a pic of the last set I made
Good Luck
-- Aj
klinkman
#5 posted 04-21-2021 06:51 PM
Thanks all for the replies, Yep, your advice coincides with the videos I just watched, work from larger to smaller holes, perhaps a longer piece. Will try that and see how it goes.
View therealSteveN's profile
therealSteveN
7694 posts in 1658 days
#6 posted 04-21-2021 07:04 PM
Follow this.
https://www.youtube.com/watch?v=lZzi0IJsITg
-- Think safe, be safe
klinkman
#7 posted 04-21-2021 07:24 PM
Love the Stanley 77 dowel maker, everyone could use one of those!
View SMP's profile
SMP
#8 posted 04-21-2021 09:03 PM
- klinkman
Actually, kind of want to make one of these when i get some more free time, worth the watch, one of several designs:
https://www.youtube.com/watch?v=3jG87WrArmE
therealSteveN
#9 posted 04-21-2021 09:19 PM
Sharp guy there. Thought you had linked the wrong video for a bit. :-)
klinkman
#10 posted 04-21-2021 11:59 PM
thanks again all, suggestions were right on. Holding the longer blank perpendicular was also important for a good result.
Two 6”+ padauk dowels, happy with these. . .!
View jdh122's profile
jdh122
1238 posts in 3902 days
#11 posted 04-22-2021 10:28 AM
Looks good. One thing I have found that you may (or not) want to experiment with is that I can get smoother, rounder dowels (but sacrificing a bit of strength since they’re no longer riven) by cutting the stock square on the table saw, chucking the square piece in a drill and then running it through the dowel plate. It’s especially useful for making longer dowels that would be likely to break while pounding them through the plate.
-- Jeremy, in the Acadian forests
