Blackstone Griddle
« back to Coffee Lounge forum
Forum topic by hairy posted 04-21-2021 04:52 PM 207 views 0 times favorited 1 reply Add to Favorites Watch
View hairy's profile
hairy
3275 posts in 4619 days
04-21-2021 04:52 PM
Smitty_Cabinetshop posted a project , a side table for his Blackstone griddle. I didn’t want to be a hijacker, so I did this instead. Congratulations Smitty, that’s a nice piece of work.
I got this one. Last spring, Covid pandemic was just getting a tight grip on all of us. And I had to have this. I can’t explain it. This is the 36”model. I’d been on the bubble about buying one, then this was $100 off, that’s all it took.
The only modification I did was to add windbreakers along the sides. I used disposable aluminum cooking pans.
As well as wind blowing in, I have noticed that a lot of heat comes out the sides. This makes the side tables almost useless, things get hot. I saw somewhere that the heat shields sold by Blackstone prevent the lid from closing. I just did that last week so I it’s still a theory.
That accessory steamer lid is new this year, haven’t tried it yet.
Here’s my fugly grill cart. It used to have a disc/belt sander mounted to it, I should be ashamed of how cheap I can be. It holds a lot of tools and necessaries, that’s the nicest thing I can say about it. Maybe it just needs a paint job?
This will more than likely be converted to natural gas soon. I have to redo some plumbing to add in another quick disconnect. My back up generator uses a 3/4” QD, this one needs a 3/8” QD. As usual,overcoming inertia is the hardest part.
I like the size. It’s nice to have different temperature zones. You can get it with or without the hood. I wasn’t getting it without a hood, just my preference. If I used it on a covered porch, maybe.
I spent several hours seasoning the cook surface before using it, time well spent. Cleanup is quick and easy.
That’s my story, and I’m sticking to it.
-- You can lead a horse to water, but you can't tie his shoes. Blaze Foley
1 reply so far
View therealSteveN's profile
therealSteveN
7702 posts in 1661 days
#1 posted 04-21-2021 06:02 PM
Fugly it is, but also appears to have the other “F” Functional.
If you opt for paint, it will likely be Tom Foolery done well :-)
-- Think safe, be safe
