Latex in HVLP sprayer ?
Forum topic by MichaelTT posted 04-20-2021 02:37 PM 245 views 0 times favorited 3 replies Add to Favorites Watch
View MichaelTT's profile
MichaelTT
47 posts in 1170 days
04-20-2021 02:37 PM
Bit off topic question, not directly woodworking…
I have some doors which I have to paint, with latex interior paint.
Can I use my HVLP sprayer for that ?
I guess the paint would have to be diluted with water, make a bit less thick ?
This is the sprayer set I have :
https://www.amazon.com/Tools-6900-9-Piece-HVLP-Spray/dp/B000M61KKG/ref=sr_1_1?dchild=1&keywords=hvlp+sprayer+set&qid=1618929322&refinements=p_36%3A1253530011&rnid=1243644011&s=hi&sr=1-1
3 replies so far
View gwilki's profile
gwilki
366 posts in 2557 days
#1 posted 04-20-2021 03:55 PM
According to the link you posted, you have a 1.8mm tip. That should work. Be sure to test on a scrap. Also, be very careful diluting with water. Look to the paint manufacturer for max dilution. It is usually 10% or less. You can use floetrol with better results.
-- Grant Wilkinson, Ottawa ON
View xedos's profile
xedos
290 posts in 384 days
#2 posted 04-20-2021 05:33 PM
Maybe.
1.8 mm might get you there with some paints, but not all . As gw says , be carefully how much you dilute paints. You can certainly add enough thinner ( floetrol IS NOT a thinner ! ) to get it to spray through your gun. But at that point you have ruined the properties of many emulsion paints. Most are in the neighborhood of 10% thinner max.
Floetrol is a conditioner that allows the paint to dry slower and level out.
What kind of compressor do you have that delivers clean , dry air 9 cfm at 30+ psi ?
Bottom line is try it, though HVLP is not really the tool for spraying latex house paint.
View CaptainKlutz's profile
CaptainKlutz
4451 posts in 2578 days
#3 posted 04-22-2021 02:57 AM
IME – Never had any luck with latex in a gravity feed HVLP, without using largest 2.2-2.5mm tip.
Even with big tip, need a maximum recommended amounts of water to thin the paint.
A turbine, pressure cup, or pressurized tank HVLP with 1.8-2.0mm tip works much better. Can rent a Graco airless unit made for spraying latex, at reasonable price for small 1-2 day jobs. Used an inexpensive HF pressure tank gun for several 2-3 gallon projects using floetrol and water thinning.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
