Alternatives to A Line It saw gauge?
Forum topic by Winny94 posted 04-20-2021 03:20 AM 611 views 0 times favorited 15 replies Add to Favorites Watch
View Winny94's profile
Winny94
56 posts in 1528 days
04-20-2021 03:20 AM
Looking for a gauge to align a table saw top. Is there a HF version of the A Line It kit?
Similarly has anyone tried the Mag Dro Miter Caliper Base as an option?
15 replies so far
View SMP's profile (online now)
SMP
3998 posts in 992 days
#1 posted 04-20-2021 03:25 AM
Hf dial indicator and make base out of scrap wood, like $15
https://www.harborfreight.com/1-in-travel-machinists-dial-indicator-63521.html
View therealSteveN's profile
therealSteveN
7702 posts in 1661 days
#2 posted 04-20-2021 05:42 AM
Do a search here for tablesaw adjustment jig. I’ve seen a few posts where people did as above, makes it easier to follow the bouncing ball.
Really simple affairs can be used with a bolt, or a screw into a board as the pics show.
-- Think safe, be safe
View tvrgeek's profile
tvrgeek
1872 posts in 2736 days
#3 posted 04-20-2021 10:43 AM
I did mine a little differently. I used a bit of pipe to ride the slot. Basically no clearance to the slot error.
Remember to use the same tooth.
View hotbyte's profile
hotbyte
1061 posts in 4062 days
#4 posted 04-20-2021 11:23 AM
tvrgeek, did you weld on the slotted flange or is that something you found/repurposed? Looks like nice solution.
tvrgeek
#5 posted 04-20-2021 12:51 PM
Yes, just a bit of band iron onto a bit of black pipe. You could just as easily use JB Weld. Or notch a bit of angle iron and screw it on.
One could use the runner like the wood jigs and add a couple of screws to expand it to fit the slot for the goiven humidity. I use HDPE runners for my sleds and fit three screws in undersize holes so I can make them as snug as I want.
100 ways to get the job done. 99 of them work. Pick one of the 99. :)
SMP
#6 posted 04-20-2021 01:40 PM
Better than using a tooth of the blade is to make a scrap piece of wood fit onto the arbor, giving you more swing. Tim Conway does a good job explaining here:
https://www.youtube.com/watch?v=AignFa1374E
View CaptainKlutz's profile
CaptainKlutz
4456 posts in 2581 days
#7 posted 04-22-2021 03:05 AM
I use the Mag Dro caliper jig. Works well, despite being a $9 hunk of molded plastic and hardware. :)
Only caution is make sure your caliper does not have electronic readout with large protrusion out the back. Have 30yr old Starrett electronic calipers that does not fit Mag Dro properly. Standard dial caliper, or newer electronic models with smaller plastic case work fine.
Cheers!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
Winny94
#8 posted 04-22-2021 04:05 AM
Cheers!
- CaptainKlutz
That’s what I ended up ordering. Seems all jigs either needed more $ in supplies or access to an already tuned saw, which I don’t have .
View Wood_Scraps's profile
Wood_Scraps
137 posts in 105 days
#9 posted 04-22-2021 02:29 PM
- tvrgeek
Agree with TVR. Million ways to skin the cat here. Ranging from cheap to expensive.
Aligning a table saw isn’t something I do often. So when I recently upgraded my saw, I just made a quick and dirty jig. Built a fixture with some scrap wood and clamped it to my miter gauge.
I prefer a dial indicator over calipers. Right or wrong, I find the former is more reliably precise in this application.
Whatever you do, make sure you’re eliminating any play when measuring. I did a lot of repeatability and reference testing. Just to ensure I wasn’t introducing any error into the measurements.
View Loren's profile
11196 posts in 4734 days
#10 posted 04-23-2021 06:12 PM
I use an ice pick held against the miter gauge. It’s pretty sensitive though I am sure not as precise as a dial indicator method. It’s been accurate enough for me.
View dbw's profile
dbw
548 posts in 2723 days
#11 posted 04-23-2021 08:13 PM
Cheers!
- CaptainKlutz
+1 on quality and +1 on overpriced.
-- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy.
View Lazyman's profile (online now)
Lazyman
7015 posts in 2474 days
#12 posted 04-23-2021 08:56 PM
I just use my combination square. We are talking about wood working after all. My table saws manual say that as long as it is within 1/32” (wider at the back), it is in spec.
View Kudzupatch's profile
Kudzupatch
198 posts in 2295 days
#13 posted 04-24-2021 12:09 AM
- Lazyman
DITTO!! Nice to hear someone else say that. I gave up saying it.
-- Jeff Horton * Kudzu Craft skin boats* www.kudzucraft.com
View Woodmaster1's profile
Woodmaster1
1737 posts in 3674 days
#14 posted 04-24-2021 09:58 AM
+1 on the combination square I have used that method for years. When I give presentations at the local woodworking store on the Tablesaw that’s the method I show them. I just have to be careful and make sure the Sawstop is off so it doesn’t need to have the cartridge replaced. If that happened they would get an added demo on changing a cartridge.
Lazyman
#15 posted 04-24-2021 03:24 PM
To clarify…the 1/32 spec I mentioned is for the fence not the blade to miter slot setup. The blade/slot setup close enough to perfect to not be noticeable.
