Drill Press Chuck Size
Forum topic by BroncoBrian posted 04-19-2021 10:47 PM 383 views 0 times favorited 9 replies Add to Favorites Watch
View BroncoBrian's profile
BroncoBrian
899 posts in 3040 days
04-19-2021 10:47 PM
Hey LJs,
Do most of you use a 1/8 – 5/8” chuck in your press and leave it alone? Or do you use 2?
I’m setting up a PM2800b and replacing the chuck, but I’m not sure if I need anything over ½” for most woodworking projects. Thinking cabinet door hinge recesses, and normal hobby/home-built furniture.
B
-- A severed foot is the ultimate stocking stuffer.
9 replies so far
View Redoak49's profile
Redoak49
5242 posts in 3070 days
#1 posted 04-19-2021 11:27 PM
Mine goes to 5/8” but rarely need that big. I think more important is small bits. I bought a keyless one that goes down to 1/32” and was about $60 on Amazon.
View Foghorn's profile
Foghorn
1212 posts in 468 days
#2 posted 04-20-2021 12:08 AM
High quality chucks will accept numbered bits. For lower quality chucks, a second, smaller chuck will be needed.
-- Darrel
View mribelin's profile
mribelin
18 posts in 2217 days
#3 posted 04-20-2021 02:15 AM
I have the same drill press, I replaced it with LLAMBRICH USA
Keyless High Torque Drill Chuck 0.512” Cap., 2MT Mount Size, Steel
This is an expensive chuck , but will hold small bits and never slips, it is so smooth. 1/2 size has been fine for all my woodworking needs.
-- MikeR Littleton, CO
View tvrgeek's profile
tvrgeek
1865 posts in 2730 days
#4 posted 04-20-2021 10:09 AM
Never needed larger than 1/2, so I got a decent key chuck that gets real small.
6986 posts in 3574 days
#5 posted 04-20-2021 10:39 AM
I replaced my 1/2” (which had a fairly amount of runout) with a new one, and sized up to 5/8”. The 5/8” chuck still goes down to 1/16” which is small enough for the stuff I do. I did eventually add a chuck for my lathe and it uses the same MT…so if I ever need something smaller I have it…but that hasn’t happened. Onwe thing I learned was that adding the 1/8” can mean a lot more than you bargained for. Here’s a pic of the 2 chucks…you can guess which is the 5/8”.
#6 posted 04-20-2021 04:57 PM
Let me correct an error in my statement above. The smaller chuck is a 5/8”, and the larger one is 3/4” (still goes down to 1/16”) I remembered the new being 1/8” larger, but forgot the starting point was 5/8”. Senior moment I guess.
View PaulDoug's profile
PaulDoug
2549 posts in 2785 days
#7 posted 04-20-2021 06:18 PM
I don’t worry about the big size much but a chuck the will not close all the way so it will take very small bits, is worthless to me… I know you can get chucks to put in you chuck to handle the tiny bits,,, but I have not had one of those mini chucks that did not wobble all over… I use lots of tiny bits as a hobbyist…
View MrRon's profile
MrRon
6020 posts in 4325 days
#8 posted 04-21-2021 03:11 AM
You really don’t need a chuck that opens to 5/8 since you can’t get drills with a straight shank over 1/2”. Usually anything over 1/2” will have a reduced shank (Silver and Deming) or have a taper shank.
BroncoBrian
#9 posted 05-03-2021 03:14 AM
- mribelin
Thanks, Mr. Ron, that is what I was expecting.
Mribelin – I was trying to get that same Llambrich and the order was canceled for lack of stock. I’ve not been able to get a ½ or 5/8 from Llambrich. I agree with what all/most of you are saying, ½ is about as big as a drill bit as we come across. I wanted to confirm that before overspending on a chuck to that size.
Ended up getting an Albrecht because it was in stock and I’m guessing I won’t need another for a very long time. Dang thing is gorgeous but expensive.
