What is soluble into Minwax poly? MEIK, Methanol, Toluene, Ethanol?
Forum topic by CanofWorms2 posted 04-19-2021 06:48 PM 447 views 0 times favorited 3 replies Add to Favorites Watch
View CanofWorms2's profile
CanofWorms2
15 posts in 1443 days
04-19-2021 06:48 PM
What is soluble into Minwax poly? Xylene/Acetone?
I’m asking because I’m using analine dye that is soluble in MEIK, Methanol, Toluene and Ethanol and my wood won’t accept any more color and I need to add to the poly coat.
I have also found that the dye dissolves really really nicely into 3M Specialty Adhesive Remover which has abunch of stuff bot mostly Xylene and acetone.
That’s ok for staining the wood, but not a great option for mixing into poly.
3 replies so far
View tvrgeek's profile
tvrgeek
1865 posts in 2730 days
#1 posted 04-19-2021 06:55 PM
Test. Paint thinner is. What does the can say for thinning or cleanup?
View Madmark2's profile (online now)
Madmark2
2651 posts in 1669 days
#2 posted 04-19-2021 10:35 PM
My can says mineral spirits or terps.
-- The hump with the stump and the pump!
View CaptainKlutz's profile
CaptainKlutz
4446 posts in 2576 days
#3 posted 04-20-2021 01:01 AM
+1 MS or turpentine. Naptha is want fastest evaporation rate.
Most solvent based polyurethane liquid coatings are compatible with aromatic hydrocarbon solvents.
My suggestion is to dissolve the dye into toluene or xylene only, and then mix that into poly. The ketones and alcohol listed options will not mix well.
YMMV
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
