Dewalt 618 Router spiral groove question
Forum topic by raduray posted 04-19-2021 12:03 AM 297 views 0 times favorited 9 replies Add to Favorites Watch
View raduray's profile
raduray
7 posts in 60 days
04-19-2021 12:03 AM
I just got my first router, a Dewalt DW618PKB combo package. The first two I got from Home Depot were missing the 1/2 inch collet so I returned them. The third one I picked up from Lowe’s had both 1/4 had 1/2 inch. But in playing with it when mounted in the fixed base I noticed the height adjustment is not smooth. I took a closer look at the spiral groove cut into the router body and noticed that the bottom of the groove doesn’t have a smooth finish. It’s rough. Is that normal?
I can’t figure out how to embed a picture, but here’s a link to one: https://i.postimg.cc/pX349Lbd/Router-Groove.jpg
9 replies so far
View MrUnix's profile
MrUnix
8563 posts in 3283 days
#1 posted 04-19-2021 12:19 AM
Not sure what exactly you are asking, but the height adjustment on mine seems to work just fine without any issues. The ‘bottom’ of the groove does show some visible machining marks, but that does not interfere with the adjuster that I can tell. Here is a quick picture of mine:
raduray
7 posts in 60 days
#2 posted 04-19-2021 12:28 AM
Not sure what exactly you are asking, ...
When I turn the plastic ring to adjust the height it’s not smooth. I can feel roughness more in some places than others. It’s like rubbing two rough stones as opposed to rubbing two polished stones.
MrUnix
#3 posted 04-19-2021 12:43 AM
When I turn the plastic ring to adjust the height it s not smooth. I can feel roughness more in some places than others. It s like rubbing two rough stones as opposed to rubbing two polished stones.
- raduray
Have you tried using a little bit of wax?
View LittleBlackDuck's profile
LittleBlackDuck
7076 posts in 1905 days
#4 posted 04-19-2021 02:45 AM
Welcome to LJ… I can’t help with the router, however, I can help with the picture.
  1. Click on the ”img” button.
  2. On the drop down, click on ”Browse”.
  3. After selecting you file (in your browser pop-up), click on the ”Insert this image” button… don’t change the syntax generated for the upload… type around it.
raduray
7 posts in 60 days
#5 posted 04-19-2021 03:45 AM
- MrUnix
Thought about it, but haven’t done that yet. I don’t remember the same roughness on the two I returned, but unfortunately I no longer have them so can’t do a visual comparison. I’ve used up my local options and may order one from Amazon to see if that’s any smoother.
Welcome to LJ… I can t help with the router, however, I can help with the picture.
  3. After selecting you file (in your browser pop-up), click on the ”Insert this image” button… don t change the syntax generated for the upload… type around it.
- LittleBlackDuck
Thank you!
raduray
7 posts in 60 days
#6 posted 04-20-2021 09:39 PM
OP here. So I ordered another 618 router from Amazon and it arrived today. The bottom of the spiral groves on this one is nice and smooth, as expected. Alas, it was missing he 1/2 inch collet. So three out of the four routers I purchased brand new were missing the 1/2 inch collet. I think Dewalt has a quality control problem.
MrUnix
#7 posted 04-20-2021 10:06 PM
Contact DeWalt. Bet they will send you a new collet under warranty rather than have to deal with a return.
View therealSteveN's profile
therealSteveN
7694 posts in 1658 days
#8 posted 04-20-2021 10:12 PM
If you felt the other 2 you got from Lowes were smoother it looks like the guy in charge of sanding the inside smooth has a better record than the guy in charge of dropping collets of both sizes in the boxes.
China made this, strikes again.
-- Think safe, be safe
MrUnix
#9 posted 04-20-2021 11:49 PM
- therealSteveN
According to the major retailers, it was made in Mexico.
