Surface cleaning moldy wood
« back to Coffee Lounge forum
Forum topic by bradleyheathhays posted 04-17-2021 07:18 AM 597 views 0 times favorited 4 replies Add to Favorites Watch
View bradleyheathhays's profile
bradleyheathhays
22 posts in 104 days
04-17-2021 07:18 AM
I have this barrel top that I’d like to clean up for a project. Wood guy that I got it from said to just use water and a wire brush but I’d like to take better care of it than that. The white specs aren’t actually there; photo anomaly or something. What kind of cleaner would go well with a nylon brush to clean things up here?
-- 'If the end of the world ever comes move to Kentucky, because everything there happens twenty years later.' ~ Mark Twain
View LittleShaver's profile
LittleShaver
752 posts in 1701 days
#1 posted 04-17-2021 11:50 AM
Start with water and brush. Then move up to adding some soap. How aggressive you get depends largely on what you’re going for.
-- Sawdust Maker
View Jeff's profile
Jeff
547 posts in 4276 days
#2 posted 04-17-2021 12:02 PM
Looks like oak so the black is from tannins in the wood. As Sawdust said depends on how clean you want it. A weak oxalic acid solution, coarse brush and muscle will clean up the black and maybe lighten the aged appearance a little. You’re right to use a plastic bristle brush. Keep wire brushes away.
bradleyheathhays
#3 posted 04-17-2021 08:19 PM
Yes thanks for the advice. I forgot to mention this is a bourbon barrel lid and I want to keep whatever color was imparted by the bourbon, so I better stay away from anything like oxalic acid. Insofar as how far I’d like to go, really just getting the black off would be good enough.
Otherwise I’ve had 50/50 bleach solution with dish soap, hydrogen peroxide, and TSP recommended. Any ideas on these?
View unbrakochaz's profile
unbrakochaz
1 post in 20 days
#4 posted 04-22-2021 06:43 PM
I agree with Jeff, I’d go down the mildly acidic route possibtl with vinegar
