What happened?
Forum topic by Rich Voytek posted 04-16-2021 11:15 AM 301 views 0 times favorited 2 replies Add to Favorites Watch
View Rich Voytek's profile
Rich Voytek
2 posts in 30 days
04-16-2021 11:15 AM
Has anyone ever seen maple react like this to staining?
-- Rich Voytek
2 replies so far
View EarlS's profile
EarlS
4451 posts in 3432 days
#1 posted 04-16-2021 11:52 AM
Did you use any sealer under the stain? My first guess is that it is an odd case of blotching. Otherwise, it also looks like something sprayed on the wood prior to staining that affected the stain process.
View CaptainKlutz's profile
CaptainKlutz
4451 posts in 2578 days
#2 posted 04-16-2021 12:26 PM
+1 sprayed on sealer before staining.
Check your door manufacture literature. Some mfg sell unfinished doors with clear grain sealer (for painted doors). If you want stain grade unfinished doors, need to order them without the seal coating.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
