Top rail cut
Forum topic by Notnickkroll posted 04-16-2021 11:14 AM 229 views 0 times favorited 6 replies Add to Favorites Watch
View Notnickkroll's profile
Notnickkroll
1 post in 30 days
04-16-2021 11:14 AM
I am novice and am putting up some board and batten trim in our bathroom. I am installing a 1×2 top rail and am having an issue on a gap in the corner that falls about an inch from the door casing. In our dinning room there is a cut on the corner i think would work. On the 1×2 laying flat it’s a straight edge for 1/4 of an inch and then it transitions to 45 degree cut. I tried a straight 45 cut but leaves too much of gap between the casing and trim.
Any help would be appreciated
View Meisterburger's profile
Meisterburger
44 posts in 322 days
#1 posted 04-16-2021 12:59 PM
A pic or drawing might help us
View Madmark2's profile
Madmark2
2660 posts in 1672 days
#2 posted 04-16-2021 01:17 PM
Cope it.
Leave the end of the short piece square and miter the end of the mating piece. Using a coping saw follow the profile of the miter undercutting slightly.
As you put this piece in against the square cut short piece it should appear mitered even though it isn’t.
A “coped” joint appears to be mitered even though it’s not.
Is old trick.
Practice on scrap first.
-- The hump with the stump and the pump!
View 1thumb's profile
1thumb
400 posts in 3240 days
#3 posted 04-16-2021 03:04 PM
do a straight rip and apply flat between casing and corner then kill all trim into it
-- I actually have two thumbs
View SMP's profile
SMP
3990 posts in 989 days
#4 posted 04-16-2021 04:15 PM
- Meisterburger
Yeah take a pic, its unclear what you are trying to do.
1thumb
#5 posted 04-16-2021 04:32 PM
or is it a jack miter you need?
View LeeRoyMan's profile
LeeRoyMan
1732 posts in 811 days
#6 posted 04-16-2021 04:56 PM
- 1thumb
That’s what I was thinking, though from the explanation, I couldn’t understand the situation.
