Sanders
Forum topic by PapaP posted 04-16-2021 02:28 AM 312 views 0 times favorited 7 replies Add to Favorites Watch
View PapaP's profile
PapaP
21 posts in 89 days
04-16-2021 02:28 AM
Good Evening Everyone…
Here is the deal. I find myself sanding large table tops and different items as such. Id like to find a better and faster way of sanding. All I use now is a belt sander and 5” orbital. Had anyone ever used a sheet rock sander on wood? I’d like to get something with at least an 8” pad. I guess one of my main qualms is trying to stay under $100. Any suggestions?
-- PapaP
7 replies so far
View xedos's profile
xedos
285 posts in 382 days
#1 posted 04-16-2021 04:23 PM
You’re asking the impossible.
What makes you think you can manually / hand sand something faster than with an orbital sander ?
If you’re doing a lot of table tops , time to invest in some equipment. A dual model sander like the Bosch GET75-6 will allow you to replace your belt sander and also do finish sanding. Though, it’s not really well suited to finish because it needs two hands.
A vacuum to attach to your sanders will also speed your process up as well as vice you a better finish.
View SMP's profile
SMP
3975 posts in 987 days
#2 posted 04-16-2021 04:25 PM
If its taking super long to sand I would question your prep work and glue up processes.
View RClark's profile
RClark
126 posts in 3266 days
#3 posted 04-16-2021 05:29 PM
Have you ever tried a card scraper?
Certainly would meet your cost requirement.
Properly sharpened and used, it would also speed the process and reduce your need for powered equipment.
I use mine mainly to remove mill marks on the surface and, depending on the piece, it’s ready for finish without sanding.
-- Ray
View Loren's profile
11192 posts in 4729 days
#4 posted 04-16-2021 06:38 PM
You can sand in theory about 30% faster with a 6” orbital sander. Ridgid sells one for about $100
View controlfreak's profile
controlfreak
2107 posts in 683 days
#5 posted 04-16-2021 07:03 PM
I would never trust myself with a belt sander on a table top.
View tvrgeek's profile
tvrgeek
1865 posts in 2730 days
#6 posted 04-16-2021 09:10 PM
Another vote for the Bosch 6 inch sander. Less vibration to your hands than most.
But that is for final smoothing. I won’t give up my long boards with PSA. Of course, if you get it flat with the long boards, then move to the scraper. Better finish as it leaves the grain open.
View CWWoodworking's profile
CWWoodworking
1755 posts in 1260 days
#7 posted 04-16-2021 09:47 PM
If you really want to sand panels, a drum sander is a fantastic way of sanding panels. Slightly more than your budget. :)
