I'm a retired engineer and am setting up a woodshop in my basement. In addition to powered and unpowered hand tools, I've got a Dewalt sliding miter saw and a Makita track saw. I'd like to avoid a table saw for now and am thinking about a router for cutting dados for joints and for putting some tracks on a workbench I'll be building.
So on to router selection. I would like a combo router (fixed and plunge bases) and I want it to be compatible with the Makita 194579-2 Router Guide Rail Adapter. I'm looking at a Makita 1-1/4 HP and at a Dewalt 2-1/4 HP. The Makita is obviously lighter and I think I like its ergonomics a bit better, but I'm wondering if it's capable of doing the kind of work I want. For example, a dado for a track would be 3/4" wide and 3/8 deep. How would the two different models be able to handle that kind of work?
My personal feeling on a router is go bigger. A 1.25 hp router is going to struggle to cut that dado in a single pass. I'm not familiar with either of those routers personally but for cutting dados, more power wins for me.
Both would do it, just depends on how fast you want to do it, ie # of passes. HP required is about chip load on the cutter. 2-1/4 could do it in 1 pass, 1-1/4 probably 2. I would probably do it in 2 or even 3 passes (last one very light finish pass) and I have 2-1/4 Bosch. Depending on the cutter hi loads can cause burning. Dont have experience with smaller size. I use a small trim router, 1-1/4 is in between. 2-1/4 is overkill for what I'm willing to do hand held, but works well in my router table. The in between size 1-1/4 wasnt available 25 years ago when I got my routers.
+For the first router I would start with a 2 (+/-) HP router that has variable speed….you've already identified the plunge/fixed base part. This won't do everything, but it will do more things that most of the other choices. I agree the 1 1/4 HP would be, well, not the best choice since it won't handle a few things. This is nly the starter router, you wll do as needed as you put together more stuff.
Most of us have multiple routers. I have a 1/4" handheld and a big 3-1/2 hp Milwaukee in the table.
The table router is used for when you can bring the work to the tool. The handheld is for when your workpiece is too big to easily move and you need to bring the tool to the work.
This is why you have a hand drill and a drill press, a table saw and a circ saw, a stationary belt/disc sander and an ROS (or two).
You'll spend more on router bits than the router itself. I just dropped $90 on a panel cutting set. Even a little 3/16" carbide bit is $15. I've got a full tray of bits. Straight cutters in various widths, radius cutters from 1/16" to 1/2", beaders, bevel cutters, etc.
Tray 'o bits, even more added since!
Why do you want to "avoid" a table saw? They are the core of most shops.
I used a PC 690 for years. Single speed… worked just fine. If your getting to the point of large bits you'll need to reduce speed, need more HP and generally run it in a router table…
With the change in routers in the last 5 or so years the Bosch 1617 seems to be a good router today for the money..
I have 3 Porter Cable 690s and a larger 3 hp PC for real heavy work (it is too heavy for regular use). I also have a couple of ancient Craftsman I sometimes use for really light stuff.
One of the 690s is hand held with two bases, fixed and plunge. One is mounted in my router table….something you will want to have next I'm sure. And, one is mounted in my PantoRouter for making mortise & tenon, dovetail and finger joints, etc.
The makita 1.25hp router ,or any 1.25hp router for that matter, is not the tool for making 3/4" dados. It's good for a lot of things, but not dadoes. 2.25hp and above. The DeWlat you mentioned is good and so is the the OSU mentioned. The Bosch also has an good dust collection accessories. Makita has one in this category , but it's hard to find and the dust accessories aren't as numerous.
Any / all of them will or can work with a guide rail. How, well is another discussion. The makita mini works outa the box as do their big plunge routers. The 2.25hp will need adapting. DeWalt's rail adapter is more universal and fits their routers as well as PC models. Festool's of course only really works with festool. Bosch's rail adapter isn't readily available in the USA.
I have a Bosch 1617 (2.25 HP?) with the fixed base and plunger base that I use with the Leigh mortise and tenon jig as well as the Leigh dovetail jig. The router table has the big 3-1/4 HP Porter Cable router motor in it, and I also have a Dewalt handheld for little jobs, typically 1/4" shaft bits for edge profiles and such. Of the 3, the Bosch gets used the most since I do a lot of mortise and tenon work and dovetails.
I also have the Bosch 1617 with both bases and another 1617 that I use in my router table (so far no problem with the larger raised panel bits that I have used). I really have been pleased with the router. I am in the market now for a small hand held battery unit - I have been using an old Craftsman 1/4" router for smaller bits but think that a new compact unit would be a good add (and a reason to buy a new tool).
- EarlS
I agree with Earl
I'm the OP. Thank you all for your recommendations. I decided to go with the DeWalt 2.25HP combo. Also got the Makita saw track adapter, which I understand works with the Makita.
I have 3 Bosch 1617's, 3 pic 690's, a skill 21/4hp, triton 31/4 hp and a Bosch colt. I don't have change bits very often. I have a Kreg full size router table, a Kreg portable router table that I use when giving presentations and homemade router table with the Incra fence system. Believe it or not I use all of them during the month for various projects. So I doubt the Dewalt router will be your last. You will keep adding to the inventory when good deals come along. 1/2 of my routers only cost me $5 each.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
