Wood vent hood
Forum topic by willhime posted 04-12-2021 12:02 AM 378 views 0 times favorited 5 replies Add to Favorites Watch
View willhime's profile
willhime
186 posts in 2626 days
04-12-2021 12:02 AM
Topic tags/keywords: question resource tip trick finishing woodburning
I’m making a wood vent hood for a friend and was wondering if there’s any sort of fire/heat safety precautions I need to know. They want it light colored so I’ll probably use maple or ash so sugi-ban is out of the question. Are there any good fire resistant finishes I should consider ?
-- Burn your fire for no witness
5 replies so far
View SMP's profile (online now)
SMP
3999 posts in 992 days
#1 posted 04-12-2021 01:03 AM
Not sure what your code is if any, Usually they are around 24” above the stove so I would be more concerned with the finish. I have used water based finishes above areas that generate steam and eventually water based finishes i have used including poly has turned into a gummy “mess” after a few years.
willhime
#2 posted 04-12-2021 06:15 AM
Yeah. That’s what I’m worried about. I’m almost tempted to sand to a super high grit and leave it raw, but I guess that’d leave it vulnerable to steam/water damage which would probably mold. Maybe a marine seal ?
View LittleShaver's profile
LittleShaver
753 posts in 1706 days
#3 posted 04-12-2021 10:44 AM
I’m not sure what finish would be best, but whatever it is needs to stand up to harsh cleaning. Cooking grease is tough to get off. I would definitely not leave it raw. There is a reason commercial kitchens use stainless.
-- Sawdust Maker
View GrantA's profile
GrantA
3128 posts in 2494 days
#4 posted 04-12-2021 11:46 AM
Typically there’s a vent hood and you just dress it up with wood. If they’re using a remote fan or something I’d use a sheet metal “liner” whether it’s a one-off or a commercially available piece.
6991 posts in 3580 days
#5 posted 04-12-2021 12:15 PM
I’d consider a 2 part finish….catalyzed lacquer or conversion varnish.
