Finish for cedar hot tub
Forum topic by AlexHolman posted 04-08-2021 01:58 PM 143 views 0 times favorited 0 replies Add to Favorites Watch
View AlexHolman's profile
AlexHolman
1 post in 12 days
04-08-2021 01:58 PM
Topic tags/keywords: finish cedar question
Hi All,
I’m planning out a build for a cedar 2-person soaker hot tub. Instead of using the traditional design of 1-in cedar boards, done barrel style, I’m thinking of using 1/4 in cedar paneling (oriented vertically), either tongue and groove, or shiplap, supported by an internal plywood frame. I’d fill the interior space of the frame with spray foam insulation, and then finish with an exterior of more cedar paneling.
I’m concerned about the possibility of the 1/4 in cedar being thin enough that water can penetrate through the boards and emerge into the interior insulation space. To counter this, I’m looking for an effective way to seal the boards to prevent water penetration. I’m not looking for a “finish” per se, especially because I don’t want something that would ultimately flake off after several months of immersion in hot chlorinated water, just something that would seal the pores of the wood and prevent water penetration. Also of note, I plan to use silicone caulk in the joints in the cedar, so I’m not concerned about traditional barrel construction where the water-activated expansion of the wood provides some of the sealing pressure.
Some ideas I’ve been kicking around:
1) Water-based polyurethane varnish applied to the void-space, insulation side of the cedar.
In my experience, water-based varnish (at least matte finish) doesn’t seem to leave a surface coat, but feels like it penetrates and just seals the wood. I’m thinking of applying to the dry-side of the boards in the hope that it would provide a barrier, without being exposed to constant hot water.
2) Thinned water-based polyurethane.
Similar idea as above, but I’m wondering about thinning the varnish out 2-3x and heavily soaking the boards, both sides, under the idea that a thin varnish would mostly penetrate deeply into the board. I’m not certain how well this would hold up submerged though, and whether it would just cook off after some time.
3) Thinned spar urethane.
Similar idea to 1 or 2, but using a product that is designed for exteriors, and thinning with oil-based thinner
4) Sanding sealer.
As I understand it, sanding sealer is designed to penetrate into a board and pre-seal it before a finish is applied. Maybe that would work for me here?
5) Oil or wax treatments.
Maybe… though I’m a bit concerned with having an oily film on the top of my hot tub.
6) Epoxy.
Probably too obnoxious and expensive for my project. I’m trying to stay under $300-$400, and painting on a 2-part seems like more than I’m shooting for.
7) ???
Any other suggestions?
Thanks,
-Alex-
0 replies so far
