Woodpeckers Router Lift Help?
Forum topic by BigMig posted 04-07-2021 10:52 AM 279 views 0 times favorited 7 replies Add to Favorites Watch
View BigMig's profile
BigMig
608 posts in 3672 days
04-07-2021 10:52 AM
Topic tags/keywords: router lift router woodpeckers router lift wheaties router table question
Hey, y’all.
I have the Woodpeckers Router lift (PRL V2) and a Porter Cable 7518 in it. The micro adjust on the table top works very well. However, when I use the lift lever, it’s very jerky: I lift and it goes too far up. When I press down, it goes too far down. Have I eaten too many Wheaties, or is there something I’m missing about the lift and or its adjustments?
-- Mike from Lansdowne, PA
7 replies so far
View EarlS's profile
EarlS
4423 posts in 3406 days
#1 posted 04-07-2021 11:25 AM
Make sure threads and belt are clean. I’ve had the same problem with various router lifts and generally it came down to crud in the lifting mechanism.
View dbw's profile
dbw
536 posts in 2695 days
#2 posted 04-07-2021 12:03 PM
I have the same issue. I’ve gotten used to it and I’ve learned how to control it.
-- Woodworking is like a vicious cycle. The more tools you buy the more you find to buy.
View Dave Mills's profile
Dave Mills
70 posts in 458 days
#3 posted 04-07-2021 01:11 PM
I have basically the same issue, and just deal with it. You can adjust the spring tension on the rod, which is supposed to help life heavier routers – maybe that would help?
View Walker's profile
Walker
464 posts in 1531 days
#4 posted 04-07-2021 03:31 PM
same here. I’m guessing the trade off is that if it were easier/smoother, than it wouldn’t be as stable while routing. Even without setting the lock, my 7518 never wanders when in use in the PRL V2. Can’t say that about other lifts.
-- ~Walker
View duc996's profile
duc996
34 posts in 2556 days
#5 posted 04-08-2021 12:41 AM
I have the same exact setup and mine did the same exact. What I found was that the two stainless steel columns were filled with dust and debris and causing it to gum up the movement. The two stainless steel shafts has a brass busing that is supposed to keep dust and junk out but, the smaller particles will eventually work its way in and accumulate causing the jerky issues. After I took them apart and cleaned it works great again. Another thing to look for if your lift gets really hard to move up and after the router has been running a while. The cause of that is over tightening of the router shoe. It should just be snug when tighten and not gorilla grip tight. HTH.
View Madmark2's profile
Madmark2
2524 posts in 1647 days
#6 posted 04-08-2021 12:45 AM
Blow the dust and make sure you don’t have infiltration into the columns. I put metal tape over any open screw holes.
Note chrome tape on base in background.
-- The hump with the stump and the pump!
BigMig
#7 posted 04-08-2021 04:48 PM
Thanks to Mark and everybody…I’ll take a close look this weekend.
