Forum topic by DonS1959 | posted 04-07-2021 02:52 AM | 528 views | 0 times favorited | 27 replies | ![]() |
OK this is probably a dumb question but here goes the way I was taught is the only dumb question is the one you do not ask I have never cut a dovetail in anything to join to pieces of wood together, I will be making three or four tail pieces for some gourd banjos that I am building for my grand kids, I will be making them out off snake wood it will basically be a L shaped tail piece with the vertical piece sliding over the dowel that runs through the gourd and the horizontal piece sitting just above and extending out over the head of the banjo. I was thinking about doing a 45 degree miter cut to tie the two pieces of the tail piece together but have since decided to do dovetail joins instead because I feel a dovetail joint will be stronger then the 45 degree miter joint I want to make my dove tail joints with a 3/8 in dovetail router bit my question is do they make a jig that will work with a router to do 3/8 dovetail joints I have purchased a set of bushings but again I have never before done dovetail joints to build anything I am looking at the MCLS dovetail jig will it work for what i am trying to accomplish Thanks for reading |
27 replies so far
#1 posted 04-07-2021 03:11 AM |
I bought a cheap General and had some problems with it, sold it on ebay and bought a Porter Cable, much better in my opinion. I think it was around $200 at Rockler but I had a coupon. Although I guess now General has a 2nd version that is supposedly better than I had. |
#2 posted 04-07-2021 09:15 AM |
Is this going to be a one-off or do you plan to make more in the future… do you want diversity… do you have a deep wallet… Check out the Leigh D4R... the small one sounds more economical, but if you want dovetails, you want the 24”. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#3 posted 04-07-2021 09:30 AM |
those are nice but I do not believe I will be making enough dovetail joints to justify the cost of the Leigh jig to start I will be making 3-5 for grand kids. you never know after that I would like to purchase a good jig set up, but as I stated I do not know anything about making dovetails so i am open to all suggestions i don’t like purchasing something and only getting two or three uses out of it and then have to purchase again to do the same job |
#4 posted 04-07-2021 10:03 AM |
After several jigs, I buckled down and gave up. https://www.stanleytools.com/products/hand-tools/cutting-tools/saws/434-in-fatmax-coping-saw/15-104 You can search the WEB and find all kinds of DIY one-off jigs for your router. Basically just using a fence and careful measuring. Unless you are spending $300 got the Leigh, you are stuck with fixed spacing and pin size. I don;t know if the $40 Horrible Freight clone of the Porter Cable works. Of course, one can buy a full set of tools from Rob Cosman. Someday I may step up. I have also looked at the various methods of jigs in the table saw and band saw. I do pretty well roughing on the BS. Ground an old chisel sides into bevels for cleanout. |
#5 posted 04-07-2021 10:27 AM |
It will take practice but A $100 dovetail saw (Veritas), marking gauges and some sharp chisels can get you there. For what its worth most jigs take a lot of practice too. I hear they can make a preacher cuss. |
#6 posted 04-07-2021 12:04 PM |
https://www.youtube.com/c/RobCosmancom/featured |
#7 posted 04-07-2021 12:12 PM |
I have watched a lot of videos and am kind of hybrid and use bits of all. I would say the bulk of how I cut is Cosman method. Instead of cutting the rabbit as the baseline I have been using four layers of tape and cutting it with my marking gauge to create a reference edge. Andy Rauls has a way of marking half blinds with tape that looks interesting that I plan to try soon. |
#8 posted 04-07-2021 02:02 PM |
Don’t know about a preacher, but there is a reason I am learning by hand! Is the Veritas saw a narrow set? I have been tempted for that one. As far as technique, there is really only one absolute correct way. The way that works for you.
#9 posted 04-07-2021 05:44 PM |
Don I bought that Leigh dovetail jig several years ago and have only used a few times. It’s got quite a learning curve and it’s not very forgiving. You’ve got to be dialed in precisely. Somewhere I saw someone suggest it would be best to have two router set for it. One with a dovetail bit the other with a straight cutting bit. If I ever get around to another project with it I might consider that. |
#10 posted 04-07-2021 06:05 PM |
The Veritas saw is nice for the money and it is a narrow blade fine tooth dovetail saw. Only negative is the handle that looks somewhat like wood is plastic. I had a Japanese pull saw but wanted the pistol grip for more control. |
#11 posted 04-07-2021 06:26 PM |
The Leigh is fairly simple to use once you understand their design and the instructions are great. There are 2 main things to dial in and both have to be PERFECT: 1) the depth of the bit itself, and the adjustment of their concentric bushing. And don’t even think about rotating the orientation of your router during the cutting process, the router must be orientated the same way for each cut because if it’s not your cuts will be slightly off no matter how centered you think your bit is to the guide bushing. Lastly, I don’t understand the science, physics or whatever behind this but just when you get everything dialed in perfectly in your cheap pine and insert your walnut, cherry, maple, or oak that you are using for your finished project, your joints won’t fit and you’ll need to fine tune them again. That’s when the preacher starts cussing. But then again it all depends on how much of a perfectionist you are. I have seen people that are proud of joints that looked like they hacked them with a chainsaw while blindfolded. -- NorthWoodsMan |
#12 posted 04-07-2021 11:33 PM |
I believe the OP has already made indication that he doesn’t want good (a Leigh) but opting for cheap. I write this to prevent dissuasion of others reading comments in this blog that may contemplate a Leigh.
The only issue I have with the manual is their ”triangle” marking system for inside/outside boards. I have devised my own method... you may need to devise one that suits you. -- If your first cut is too short... Take the second cut from the longer end... LBD |
#13 posted 04-07-2021 11:49 PM |
If you are running a business you have to justify expenditures. A hobby is about fun and relaxation. There is no room for the nasty word “justification”. -- Alaskan's for Global warming! |
#14 posted 04-07-2021 11:49 PM |
Sounds complicated, give me a saw and marking gauge for limited cuts. Batching out drawers for production, give me the most expensive jig I can get. |
#15 posted 04-08-2021 12:06 AM |
Snake wood?! Thats like rock. Polishes up nice with 2000 grit automotive wet/dry sandpaper tho. Are you locked into dovetails? For under $150 you can get a Fast-Joint Mini that will do four types of decorative “dovetails.” I got good results on the first try — read my review HERE
-- The hump with the stump and the pump! |
Forum | Topics |
Woodworking Skill Share
13251 |
Woodturning
2832 |
Woodcarving
580 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6409 |
7949 |
32968 |
CNC Woodworking
335 |
Hand Tools
6491 |
Jigs & Fixtures
1826 |
Wood & Lumber
7314 |
1647 |
Focus on the Workspace
2645 |
1273 |
Woodworking Trade & Swap
5439 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9687 |
