Is it possible to run a 2hp Dust Collector and Saw on a single 240v/30amp dryer circuit?
Forum topic by JonCrafting posted 03-29-2021 06:44 PM 1350 views 1 time favorited 31 replies Add to Favorites Watch
View JonCrafting's profile
JonCrafting
17 posts in 402 days
03-29-2021 06:44 PM
Topic tags/keywords: table saw dust collector dc ts tablesaw 250v 240v 220v 30amp garage electrical dryer drier
I am sure this is a common delimma for a lot of growing woodworkers, but due to the amount of other electrical questions about 240v this and 120v that and dust collectors and table saws in general, I have not been able to sift through the search results to find a post that directly addresses this question.
As the title states, I have a typical 240v/30amp circuit wired to my garage intended for an electric dryer. I would like to repurpose this circuit for use with my 2HP/12amp dust collector and 2HP/7.5amp table saw. I have been looking into this question for several weeks now and am still not sure I have a clear understanding.
While I would love to hire an electrician to upgrade my main panel, run a new 100amp circuit to the garage with a new sub-panel, and totally rewire the garage with outlets for everything, that will need to wait as there are other priorities higher on the totem pole. I understand that the running amps listed on the DC and TS do not account for the surge of amps they will draw on start up. I am wondering if both pieces of equipment are not turned on at the same time, if the 30amp breaker could work.
I would love to know what others have done or tried to do to deal with this scenario. Assuming that it is possible, I’m wondering how one would go about re-wiring the outlet(s) in series.
31 replies so far
View HokieKen's profile
HokieKen
19055 posts in 2348 days
#1 posted 03-29-2021 06:51 PM
In short, yes. I see no reason you can’t run both of those on a single 30A circuit. Even with startup loads, the spike should be short enough that it wouldn’t throw the breaker. Running a second outlet is the same as running a 115V outlet with the exception that there’s an extra wire and the wire will be larger. Just use a pigtail to split the line at the first outlet and run it to the second outlet.
This of course is dependent on local codes. I think in most locations that multiple outlets are allowed on a single 230 circuit but you should check and make sure for your locale.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View misbeshavings's profile
misbeshavings
32 posts in 3854 days
#2 posted 03-29-2021 08:01 PM
Absolutely you could do that. You could also put a junction box there, take out the dryer plug, and run conduit and 220 receptacles closer to your machines. That’s what I did in my first garage shop. Second one didn’t have a dryer outlet, so I had to run a line all the way across the house from the outside box. Still worth it!
View WhyMe's profile
WhyMe
1409 posts in 2771 days
#3 posted 03-29-2021 08:31 PM
Are both the dust collector and tablesaw 120V? If so and the dryer circuit is 4 wire, 2 hot, neutral and a ground you can split the circuit into two 20A 120V circuits with a shared neutral. The 30A breaker will need to be changed to a 2 pole 20A breaker or two single pole 20A breakers with a handle tie. Obviously the circuit will no longer be used for a dryer. If you are on the International Residential Code multiple outlets on a single circuit are not allowed if over 20A.
View Ruscal's profile
Ruscal
109 posts in 388 days
#4 posted 03-29-2021 08:48 PM
You are only supposed to use 80% of the circuit, so 24A. 12A (DC) + 7.5A (TS) – you are fine. The DC will have a higher start load for an instant to get the blower wheel turning. You may have to run the machines in that order: Start DC first, then start TS.
-- Have a hobby? You should have a business.
View CaptainKlutz's profile
CaptainKlutz
4854 posts in 2704 days
#5 posted 03-29-2021 08:58 PM
- Yes.
Per NEC 430, need 125% of FLC (not FLA) for a motor circuit. (2) 2HP motors have 12A FLC * 125% = 30A
- NEC code only allows multiple receptacles on 20A building wire circuits.
Can not make a permanent circuit with more than one 30A receptacle, though you can permanently connect more than one machine with dedicated wiring to a circuit greater 20A, that meets code requirements.
You can use a temporary cable with 30A plug, and several 15/20A receptacles.
Leviton makes this easy with a #5822 duplex 2 wire 240v 20A receptacle. They also make #16462 Decora version. Can place one of these in an outdoor junction box, and use 10-3 SOOW cable with a 30A matching dryer plug on end. If cord length exceeds 120ft, then suggest 8-3 SOOW cord to avoid voltage drop.
PS – Not an licensed electrician. Only a EE that has played with power and learned some codes.
If any of the above does make sense, hire a professional to help you.
YMMV
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
WhyMe
#6 posted 03-29-2021 09:38 PM
”- NEC code only allows multiple receptacles on 20A building wire circuits.”
There is no such NEC restriction. The IRBC limits multiple outlets to 20A.
JonCrafting
#7 posted 03-29-2021 10:02 PM
Thanks for all the responses and advice.
@WhyMe I’m so sorry, I thought I had clarified in my post that both the DC and TS would be running on 240v, but apparently not.
@HokieKen, @Ruscal That would be great if i don’t have to worry about timing the start up times. I guess the only way to tell would be to test and see.
@misbeshavings I like this idea, and imagine it would be better/safer than long dropcords.
@CaptainKlutz I like the idea of the duplex receptacle, but it is unclear if the 20A rating on the receptacle is signifying the output or input. I could be wrong, but as the circuit is 30A, I would be hesitant to put anything rated less than 30A in the line.
View ibewjon's profile
ibewjon
2587 posts in 4003 days
#8 posted 03-29-2021 10:05 PM
A 2 hp motor on 240 v draws 12 amps, so your table saw is not 2 hp. Is it a Craftsman where they sell you ‘developed’ hp? A 1 hp draws about 8 amps on 240. I would have a sub panel installed with separate breakers for each motor, as long as you have a grounding conductor. In rush / start up current for a motor is about 3x running current.
HokieKen
#9 posted 03-29-2021 10:18 PM
As WhyMe and CaptainKlutz stated, you can’t add outlets to that circuit. I was unaware there was a 20A cap when I originally replied. I think I would pull another 20A circuit or make a pigtail extension cord to plug the machines in. Having a code violation could be bad if there’s a fire or something even if it’s totally unrelated.
WhyMe
#10 posted 03-29-2021 10:21 PM
The building wiring is governed by the NEC, so a 240V 30A dedicated single outlet circuit needs to have a 30A or greater amp outlet. A 20A outlet on a 30A circuit is a no go. Using an adapter cord going from a 30A plug to a 20A socket end is an option. The correct way is to mount a small subpanel fed by the 30A circuit and have two 240V 20A circuits from that subpanel. Or one 240V 20A with multiple 20A outlets.
ibewjon
#11 posted 03-29-2021 10:39 PM
An adapter cord with a 20 amp female is not an option without changing to a 20 amp breaker. There are adapter plugs at big box stores that allow plugging a 20 amp cord into a 15 amp receptacle. It is not UL listed.
TopamaxSurvivor
22070 posts in 4886 days
#12 posted 03-29-2021 11:17 PM
- JonCrafting
That is correct. 20A outlet needs to be protected by a 20A breaker or fuse.
Edit: The only place that overrated fuse protection is allowed is branch circuits with several 15 amp outlets protected by a 20 A breaker. If the 15 amp outlet is on a circuit by itself. it would require 15A protection.
JonCrafting
#13 posted 03-29-2021 11:26 PM
Thanks for the additional comments.
@iblewjon Not sure, where your info comes from, but “2 HP, 120V/240V (prewired for 120V), single-phase, 15A/7.5A ” is strait off of the grizzly website, for the Shop Fox W1837. I can’t argue based on personal experience, I’m just going off of the specs that have been made available.
@HokieKen If by “cap” you mean maximum capacity, your first understanding is correct and the cap is 30A not 20A. I was however responding to CaptainKlutz’s who linked a 20A receptacle as a possible solution to put on my 30A circuit.
@WhyMe I agree that the best scenario might be to create a 240v/30A sub panel in the garage. That does sound a bit more costly though, so I will need to price it out to see.
TopamaxSurvivor
#14 posted 03-29-2021 11:44 PM
@iblewjon Not sure, where your info comes from, but “2 HP, 120V/240V (prewired for 120V), single-phase, 15A/7.5A ” is strait off of the grizzly website, for the Shop Fox W1837. I can t argue based on personal experience, I m just going off of the specs that have been made available.
- JonCrafting
That is probably the National Electrical Code rating. About 15 or 20 years ago all the power tools HP doubled. I believe they started using locked rotor current instead of full load to rate HP ;-((
JonCrafting
#15 posted 03-29-2021 11:52 PM
- JonCrafting
- TopamaxSurvivor
Thanks TopamaxSurvivor. So you are saying that either the HP or the Amp draw listed on the Grizzly website is not accurate and is based on an older formula? I can understand companies picking and choosing the formula they use for different specs in order to improve marketing, but was not aware this was the case for Grizzly/Shop Fox.
showing 1 through 15 of 31 replies
