Tapping plexiglass
« back to Coffee Lounge forum
Forum topic by bradleyheathhays posted 03-21-2021 09:33 AM 510 views 0 times favorited 4 replies Add to Favorites Watch
View bradleyheathhays's profile
bradleyheathhays
39 posts in 266 days
03-21-2021 09:33 AM
Say you had a 1/2” thick sheet of plexiglass and needed to tap a hole that was drilled beginning on the edge and continuing in 3 in. What type of thread density would you choose, coarse or fine? The strain on the anchor will be fairly minimal.
-- 'If the end of the world ever comes move to Kentucky, because everything there happens twenty years later.' ~ Mark Twain
View Steve Peterson's profile
Steve Peterson
428 posts in 4325 days
#1 posted 03-21-2021 05:10 PM
I would use a fine thread since there would be less material to remove and you have a light load. Coarse threads might be better if the load was heavy.
Other random thoughts:
Why so deep if the load is minimal? Use a drill press to help drill along the center.
There are drill bits designed for plastic or you can modify an existing bit to cut better.
Use a sharp tap that has not been used to cut steel.
Sandwich the plexiglass between two boards and clamp it in a vice to help prevent a crack forming.
Use a cutting oil so the tap cuts instead of pushing material around.
-- Steve
bradleyheathhays
#2 posted 03-21-2021 07:39 PM
Thanks Steve. I tend to ‘over-insure’ things so that’s the reason for the 3” depth.
View Jim Jakosh's profile
Jim Jakosh
26786 posts in 4349 days
#3 posted 04-03-2021 12:57 PM
I think either fine or coarse will work but how big of a tap will you be using? If it is 1/2 stock and you are going in from the end I would not go over 1/4” so the wall does not get too thin. Plexiglass is brittle. Clean out the chips often because that stuff can plug the tap and make it hard to back out the tap.
If you are going to tap in 3” you will need a very special tap..a long one with a turned down body. 1 1/2 x the tap diameter will give you all the holding power you need
My 2 cents worth…........Cheers, Jim
bradleyheathhays
#4 posted 04-07-2021 06:38 PM
Thanks Jim. I don’t have a lot of experience tapping, especially acrylic so every bit of advice is helpful. I’m learning that I probably won’t have to tap as deep like you mentioned so I’ll be adjusting that in the final design.
