5/8" miter gauge?
Forum topic by Beuford posted 03-19-2021 09:35 AM 259 views 0 times favorited 4 replies Add to Favorites Watch
View Beuford's profile
Beuford
19 posts in 68 days
03-19-2021 09:35 AM
I have an older sander and band saw that use a 5/8” T-slot. The cheap plastic miter gauge I had bit the dust, and I threw it out before I realized that they are made of unobtainium.
Any idea where I can get a quality 5/8” miter gauge??
Thanks in advance,
Beuford
View tvrgeek's profile
tvrgeek
1857 posts in 2724 days
#1 posted 03-19-2021 09:49 AM
There are odd size gauges out there if you GOOGLE around. I have seen them listed in about 4 widths. Maybe not Incra or Osbourn quality, but available.
You could always trim down some HDPE and bolt it to any gauge head.
View splintergroup's profile
splintergroup
5096 posts in 2297 days
#2 posted 03-19-2021 03:41 PM
You can buy lengths of .625” width steel from the many suppliers (I got some .750” from MSCdirect.com)
It then is usually a simple matter to attach this bar to a miter head from a standard .750” unit.
Be sure to carefully measure the dimensions of your slot. .625” steel (or aluminum) won’t work well unless there are a few thousandths of clearance.
11187 posts in 4722 days
#3 posted 03-19-2021 03:46 PM
Some of the old Craftsman miter gauges are narrow gauge, 5/8” I think. I filed one down to fit a bandsaw with a dovetailed slot once.
There will be a lot of the gauges on ebay. Ask the seller and find the right one.
In terms of quality, Craftsman had several different designs. I had one with a shot pin detent every 5 degrees I liked.
View CaptainKlutz's profile (online now)
CaptainKlutz
4426 posts in 2569 days
#4 posted 03-19-2021 09:50 PM
Quality 5/8” miter?
Good luck. >> https://www.lumberjocks.com/topics/307991
+1 Have to buy a quality miter and change the bar.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
