have I ruined my V tool
« back to Woodcarving forum
Forum topic by Karda posted 03-13-2021 06:17 AM 650 views 0 times favorited 10 replies Add to Favorites Watch
View Karda's profile
Karda
3382 posts in 1885 days
03-13-2021 06:17 AM
have I ruined my V tool yet I had to remove a lot of steel to even get to the cutting edge and I am not there yet. All I can see if i continue is a 3 MM parting tool instead of sa 6 and that will be worthless here are some example
10 replies so far
View wood2woodknot's profile
wood2woodknot
111 posts in 3305 days
#1 posted 03-13-2021 06:52 AM
Looks like a twin to mine.
-- ajh
Karda
#2 posted 03-13-2021 07:04 AM
thanks at leas I am not alone
View Underdog's profile
Underdog
1802 posts in 3367 days
#3 posted 03-13-2021 12:44 PM
Can’t really tell because it’s so out of focus.
I don’t think it’s ruined though. You’d have to remove a lot more material to ruin it. Or overheat it.
I don’t understand why you said it is becoming 3mm rather than a 6mm tool. The only way to do that is if you ground off the top of the Vs?
-- Jim, Georgia, USA
View John Smith's profile
John Smith
3033 posts in 1494 days
#4 posted 03-13-2021 01:59 PM
did it ever turn blue ?
try not to keep any material that turned blue during the grinding process.
and no, you are not alone. . . . I have some V-Tools that are at least 2” shorter than when new.
but the angle that you show is not right – that is trial and error until you find what works for you
in your style of holding the tool and material being carved.
this is the profile of my V tools that work for me in my way of doing things. (YMMV)
-- I am a painter: that's what I do, I like to paint things. --
Karda
#5 posted 03-13-2021 04:26 PM
when i say I will have a 3mm tool when I am done it seems as if all I am doing is wasting away metal and not getting to the edge, No blue but onw wing tip is rounded back by about a 32nd. sure the tool isn’t worth alot but if i ruin it it will be 30 to 40 dollars to replace it.
View Phil32's profile
Phil32
1631 posts in 1234 days
#6 posted 03-13-2021 04:35 PM
Karda – In the 2nd & 3rd photos, it appears the inside of the “V” is curved. Unless that is a sharp “V”, the best you can form might be a #11 parting tool. You might try using a file or slipstone on the inside.
Note in John Smith’s photos – The tool at the left end is a #11. The others are (L to R) #13, #12, #13, #13, #22, ? (Looks like he switched the last two between the photos>)
-- You know, this site doesn't require woodworking skills, but you should know how to write.
Karda
#7 posted 03-13-2021 04:57 PM
yes the inside is curved but even a slip would leave some curve. i’m beging to think I need to be a machinist to do anything. Why do manufactures make tools so rough when the average beginner don’t have machinist skills. The descrition says they require sharpening, this kind of reshaping is way more work than sharpening. It looks like I will be useing my knife for my Vtool work
View ClaudeF's profile
ClaudeF
1432 posts in 3038 days
#8 posted 03-13-2021 10:48 PM
I agree with Phil about your second photo, although I think it’s more of a “soft V” #14, such as John’s first tool. A #11 is more “U” shaped, in my experience. Very useful for some things.
Here’s a link to the Pfiel tool profiles for you: https://www.woodcraft.com/blog_entries/pfeil-tools-chart
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
Karda
#9 posted 03-13-2021 11:39 PM
the tool is stamped #12 6mm. The inside is curved. what is this type of V tool used for
Phil32
#10 posted 03-14-2021 02:16 AM
The #12-6mm is probably the most common V-tool and is offered by most manufacturers. It has a 60 deg V-angle. It is used for grooves like Santa beards, and other representations of hair.
