Looking for recommendations for cleaning bandsaw wheels and blade
Forum topic by dv8eod posted 03-11-2021 07:34 PM 940 views 0 times favorited 14 replies Add to Favorites Watch
View dv8eod's profile
dv8eod
134 posts in 466 days
03-11-2021 07:34 PM
Topic tags/keywords: question pine bandsaw
The reason I am asking is that I finished resawing a bunch of pine from pallets that apparently wasn’t fully dry. The pitch has gummed up my blade and the gullets are full of sawdust that has hardened. On top of that, there are lines of pitch and dust stuck to the wheels.
Are there any suggestions for a cleaning product that will not damage the rubber or other parts in the machine? I’m thinking a dremel and wire wheel will suffice for the blade itself, but if there are any ideas that mean less mess and are faster, I am open to hearing them.
Thank you.
14 replies so far
View bondogaposis's profile (online now)
bondogaposis
6067 posts in 3634 days
#1 posted 03-11-2021 08:02 PM
Yes, margarine will dissolve pine pitch, then you can clean off the margarine with soap and water. It’s an old woodsman trick.
-- Bondo Gaposis
View splintergroup's profile
splintergroup
6018 posts in 2506 days
#2 posted 03-11-2021 08:56 PM
I just coil up my BS blade and clean it like I do my table saw blades. A 5 gallon bucket with enough ammonia/water mix of Simple Green to cover and let it soak for a few hours.
For the BS tires, I have a scraper I use against the tire while spinning the wheels by hand.
Blade guide parts can get fouled as well so check those out!
View Foghorn's profile
Foghorn
1344 posts in 670 days
#3 posted 03-11-2021 09:00 PM
Yes, margarine will dissolve pine pitch, then you can clean off the margarine with soap and water. It s an old woodsman trick.
- bondogaposis
Works great for getting gum out of your hair too!
-- Darrel
View Bill White's profile
Bill White
5361 posts in 5244 days
#4 posted 03-11-2021 09:02 PM
+1 on the Simple Green. Works for me.
-- [email protected]
View Robert's profile
Robert
4785 posts in 2764 days
#5 posted 03-11-2021 11:00 PM
Krud Kutter – give it a try!
dv8eod
#6 posted 03-12-2021 12:36 AM
Thank you gentlemen for all the tips. I’ll be trying them out in the next couple of days as I still have to do some more cutting, thankfully no more resawing.
(sigh- the things we do for our wives…..)
Just to be clear, the margarine doesn’t need to be melted, just spread on and let sit for a bit?
View Loren's profile
11307 posts in 4931 days
#7 posted 03-12-2021 12:51 AM
I was just reading up on cleaning planer beds and acetone was cited as effective.
View Wood_Scraps's profile
Wood_Scraps
203 posts in 302 days
#8 posted 03-12-2021 01:27 AM
Lot of good recommendations. I work quite a bit with pine. I’ve found a roughly 50/50 mix of laundry detergent and water works really well.
Mix it in a little spray bottle. Spritz it on. Then use a nylon or brass brush to scrub the teeth. I’ll then rinse the blade with water and dry it off.
Just did this with one of my TS blades yesterday. Makes the teeth shine like new.
View Bstrom's profile
Bstrom
360 posts in 457 days
#9 posted 03-13-2021 02:15 PM
I use Mineral Spirits on the tires and Thinner on the blade.
-- Bstrom
bondogaposis
#10 posted 03-13-2021 02:20 PM
No, it doesn’t need to be melted, just room temperature so it is just a bit soft. I just use the kind that comes in a tub which is already soft. Just work in the margarine into the pitch with your fingers and the pitch should come off with a paper towel. It will leave your bandsaw tire a bit greasy, so then wipe it down with a damp soapy rag to remove the margarine.
-- Bondo Gaposis
dv8eod
#11 posted 03-22-2021 11:55 PM
Following up on this little project, I used margarine on the wheels and Goo-Gone on the blade itself. The margarine did wonders; thanks for the tip bondogaposis! It was a little messy but cleaned it off pretty nicely. The margarine also kept the dust down as it was coming off, which was nice. The blade I sprayed until it was fully coated and let set in a bucket for a few minutes. Then I took it out in the yard and hosed it off. Blew all the pitch and dust right off. I lightly oiled it before coiling it up and putting away until it’s needed again. I’ll use alcohol to get rid of the oil at that time. I’m thinking it probably would have been better if I wiped it down with wax instead. Then I could have just put it back on and ran with it, without needing to take the time to clean it off again.
So, thanks again everyone for the help.
View CWWoodworking's profile
CWWoodworking
2285 posts in 1462 days
#12 posted 03-23-2021 12:43 AM
Razor blade.
View Harryn's profile
Harryn
93 posts in 3871 days
#13 posted 03-23-2021 01:36 PM
I have mounted the tip of an old toothbrush so it wipes the wheels continuously. It keeps them clean.
View rizzo's profile
rizzo
84 posts in 2535 days
#14 posted 03-23-2021 01:50 PM
I clean my tablesaw blades and bandsaw blades with boeshield. They make a cleaner that just melts away anything on the blade and leaves them looking like new. I love it and it’s super easy I just do it in a utility sink and it’s really quick.
