Question on fastening deck beam together
Forum topic by isuhunter posted 03-10-2021 07:24 PM 693 views 0 times favorited 13 replies Add to Favorites Watch
View isuhunter's profile
isuhunter
23 posts in 1391 days
03-10-2021 07:24 PM
My beam will be – 3 – 2×10’s with 2 – 1/2” treated PLY sandwiched between them to bring to the full 5.5” dimension. Now when putting the beam together, how long of screws would you use I plan to screw from both sides? 5 1/8” GRK RSS screws? Or is screwing the into the middle 2×10 just as structurally sound?
13 replies so far
View Wood_Scraps's profile
Wood_Scraps
203 posts in 351 days
#1 posted 03-10-2021 09:58 PM
I’m personally inclined to go for bomb proof and simplicity when fastening. So, I’d choose the 5 1/8” ones and call it a day.
I suppose you could opt to fasten them in a way that you end up with 2 “halves”. Then fasten those halves together. But, I’d still think the 5 1/8” screws would be best.
Whatever you decide, you’ve got the screw brand correct. Absolutely love GRK fasteners. Have tried many different brands, but always come back to the GRKs.
View tvrgeek's profile
tvrgeek
2303 posts in 2981 days
#2 posted 03-10-2021 10:14 PM
And glue.
You needed the beam to be that short for a reason?
View LeeRoyMan's profile
LeeRoyMan
2377 posts in 1059 days
#3 posted 03-10-2021 11:23 PM
3”- 4” from both sides.
View Knockonit's profile
Knockonit
1063 posts in 1534 days
#4 posted 03-10-2021 11:40 PM
using a pattern for screwing, same line can and will cause splits .
-- Living the dream
View CWWoodworking's profile
CWWoodworking
2311 posts in 1511 days
#5 posted 03-11-2021 12:57 AM
If your trying to clear span a long distance, steel beam wrapped in 2x’s would be easier and less bouncy.
I have a clear span 22’. Very little bounce.
woodbutcherbynight
10630 posts in 3741 days
#6 posted 03-11-2021 02:43 AM
- CWWoodworking
I remember doing that on a job with my Grandfather when I was a kid. My Dad thought I was kidding when I told him about it.
LeeRoyMan
#7 posted 03-11-2021 03:01 AM
It would probably be best to drill through and use a nut and bolt with washers.
View rbrjr1's profile
rbrjr1
217 posts in 1538 days
#8 posted 03-11-2021 03:23 PM
- CWWoodworking
it’s called a flitch beam.. usually 3/8”-1/2” steel is the sandwiched medium. if it’s an outdoor beam, I would recommend rubber flashing over the top of the beam so as to prevent the intrusion of water contacting the steel from the top when it rains.
-- only an idiot dismisses an intelligent statement because they dont know anything about the person delivering it.
CWWoodworking
#9 posted 03-11-2021 05:27 PM
- CWWoodworking
it s called a flitch beam.. usually 3/8”-1/2” steel is the sandwiched medium. if it s an outdoor beam, I would recommend rubber flashing over the top of the beam so as to prevent the intrusion of water contacting the steel from the top when it rains.
- rbrjr1
We used a 4×12 rectangle tube, welded closed on each end. I think the 22’ length was 600$ give or take. But it’s much easier to work with. Set it in place and build.
isuhunter
#10 posted 03-12-2021 02:42 PM
Thanks for all of the thoughts guys – here is what we are doing – 4’ OC span for posts
CWWoodworking
#11 posted 03-12-2021 05:13 PM
Your beam is way over built. 2 2×10s is plenty. Your not gaining anything by building thicker.
Good luck.
isuhunter
#12 posted 03-12-2021 05:38 PM
Good luck.
- CWWoodworking
Completely understand more a play on aesthetics, nothing drives me more crazy than seeing decks in the neighborhood that look wimpy or getting on a deck that moves a little.
View kimballd's profile
kimballd
40 posts in 3096 days
#13 posted 03-14-2021 02:12 PM
You can get a 5 1/2” x 10” treated PSL from your local lumber yard. Don’t both with the big box stores.
Good Luck, Kimball
