Forum topic by TX_1234 | posted 03-06-2021 05:40 PM | 422 views | 0 times favorited | 6 replies | ![]() |
Topic tags/keywords: humor question mdf keepsake box Hi all, I received some really nice burl veneer that has already been glued onto 1/2” MDF. I plan to make a keepsake box where one assembles the box and then cuts the top off of it. When the box is opened, however, the MDF will show along the cut face. Should I just finish the MDF like the rest of the box (e.g. oil) or try to hide it somehow? I’m afraid if I cover it with a strip of veneer, then there will be a visible line across the front of the box and ruin the continuous grain pattern. Any ideas? Thanks! |
#1 posted 03-06-2021 06:59 PM |
Hide it. MDF is never pretty. -- The hump with the stump and the pump! |
#2 posted 03-06-2021 08:22 PM |
Line it with felt. -- Live to tell the stories, they sound better that way. |
#3 posted 03-07-2021 01:53 AM |
Yep. Or flock it. -- Andy - Seattle USA |
#4 posted 03-07-2021 12:10 PM |
Glue on a solid wood rim cut through middle to separate top. Do this to the panels before assembly. Or, glue on a strip of veneer. That said, I made a prototype once, sanded the mdf real good and painted black. Didn’t look as bad as Imthou.get it would …..but don’t do that! -- Everything is a prototype thats why its one of a kind!! |
#5 posted 03-07-2021 12:32 PM |
Oops, Robert beat me to posting solution. Instead of solid mdf panel, make panel(s) with 1/2×1/2 strip of walnut on the cut line. Inside can be contrasting wood panels, veneer, felt, or flock coated to hide the natural edge/MDF. Have used up to 1/2” natural wood edges on couple of veneered Classic Core (MDF faced plywood core) table tops, instead of veneer edges. Needed to support milling an edge radius. Have never used this technique on a box, but expect it work same? YMMV -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 03-07-2021 04:44 PM |
Many thanks for the helpful suggestions. Since I have a highly figured burl veneer, I was trying to hide the cut line as much as possible (red line in sketch) to maintain the continuity of the burl across the cut line. It thought about using a v-groove routing bit to inlay a piece of wood on the cut face and then sand down any piece that sits proud of the surface, but that would require an extreme level of precision. I think I may just go with a thin piece of veneer on the cut face and simply treat that line as a design detail. |
Forum | Topics |
Woodworking Skill Share
13246 |
Woodturning
2830 |
Woodcarving
578 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6400 |
7942 |
32946 |
CNC Woodworking
335 |
Hand Tools
6488 |
Jigs & Fixtures
1825 |
Wood & Lumber
7310 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5436 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
