Forum topic by sawdustmaker1961 | posted 03-05-2021 11:19 AM | 2236 views | 0 times favorited | 36 replies | ![]() |
Topic tags/keywords: question bandsaw bogging down Good Day All ! I have a 14” Band saw that I recently bought used, I installed a 3 tpi blade (new) & set it up according to the U tube videos I watched. It has a 3/4 h.p. motor. The saw is 26 years old. My problem is when I cut it bogs down really bad! It also sounds sick while it gets up to speed before I start cutting, then it sounds all right. Would this be belt tension? or something else? Any input would be most appreciative! -- Two Wrongs don't make a right ! |
36 replies so far
#1 posted 03-05-2021 12:32 PM |
I assume the motor has a capacitor on it, maybe two. Test them to make sure they are not weak. Also don’t run it on a long undersized extension cord. |
#2 posted 03-05-2021 01:06 PM |
It also sounds sick …. – sawdustmaker1961Define sick? Growl, screech, whine, clunk, etc…. Specifically where does noise originate from? Band saw is pretty simple. With blade removed, spin the upper wheel. Turn on saw. Motor should not make any sick noises without blade either. - Are belts loose or dirty? Are they slipping? Disconnect power. Remove the drive belt(s) between motor and lower wheel. With belts removed, spin lower wheel. If nothing makes any noise with blade off, try a different blade. :) My SWAG with 26 year old band saw is 1st belts, 2nd the bearings. Best Luck! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#3 posted 03-05-2021 01:09 PM |
You did not say what you were cutting. It should chew through an inch of Oak, but don’t expect a 3/4 HP to re-saw 8 inches of hardwood at more than a snails pace. Mine will go right through, but it is a 3 HP. WhyMe had good advice. Actually hard to test. Might consider replacing. On the belt, if it squeals, it’s too lose. If too tight, it will wear out the bearings. Usually an older belt will have set and a new belt will lower vibration. If a V belt, then an AX series Gates. Most use a multi-rib though. |
#4 posted 03-05-2021 01:47 PM |
Make sure it isn’t wired for 230 and being plugged into 115. Or visa-versa. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#5 posted 03-05-2021 02:03 PM |
Thanks guys, all good advice, when I get home from work I’ll check out everything you had to say! As far as what I was sawing, it was just 3/4 ply. -- Two Wrongs don't make a right ! |
#6 posted 03-06-2021 04:45 AM |
Should we assume the blade is sharp? Even a good saw will have trouble cutting with a dull blade. -- No trees were harmed while sending this message; however, a rather large number of electrons were terribly inconvenienced. |
#7 posted 03-06-2021 04:55 AM |
Way too little info – way too many possibilities. I would start with what Ken said – make sure it’s wired correctly and you are providing the proper voltage. Symptoms do sound a lot like trying to run a machine wired for 240v on a 120v circuit. Then we can move on to figuring out the “Sounds sick” problem. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#8 posted 03-06-2021 06:02 AM |
The label you showed has the wiring diagram. Make sure it’s wired for correct voltage. -- I intended to be a woodworker, but turned into a tool and lumber collector. |
#9 posted 03-06-2021 01:33 PM |
It’s wired for 110v, after checking the bearings like the Captain suggested, it appears to be ready for new bearings. I’ve been trouble shooting for a little while & now I’m figuring out how to pull the bearings. -- Two Wrongs don't make a right ! |
#10 posted 03-06-2021 03:32 PM |
I’ve never pulled bearings that were installed like this, anybody else? -- Two Wrongs don't make a right ! |
#11 posted 03-06-2021 03:35 PM |
This is the motor side -- Two Wrongs don't make a right ! |
#12 posted 03-06-2021 03:37 PM |
I pulled a snap ring off of the motor side, and have been tapping on it using liquid wrench, with no results -- Two Wrongs don't make a right ! |
#13 posted 03-06-2021 03:42 PM |
New information: Which bearings need replaced, and how bad are they? Suspect a possible capacitor or centrifugal switch issue due issues with wimpy 3/4” cut. How many capacitors are mounted on motor? 1, or 2? Make sure to inspect the motor carefully. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#14 posted 03-06-2021 04:07 PM |
Captain, I don’t see any capacitors mounted on the motor, at least not the ones I’m familiar with -- Two Wrongs don't make a right ! |
#15 posted 03-06-2021 04:11 PM |
It’s the lower bearing on the 14 ” wheel that made the noise when I ran the motor without the blade -- Two Wrongs don't make a right ! |
Forum | Topics |
Woodworking Skill Share
13250 |
Woodturning
2831 |
Woodcarving
580 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6408 |
7948 |
32963 |
CNC Woodworking
335 |
Hand Tools
6491 |
Jigs & Fixtures
1826 |
Wood & Lumber
7313 |
1647 |
Focus on the Workspace
2645 |
1273 |
Woodworking Trade & Swap
5439 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9686 |
