Box joint set
Forum topic by 75c posted 03-05-2021 10:23 AM 492 views 0 times favorited 18 replies Add to Favorites Watch
View 75c's profile
75c
208 posts in 82 days
03-05-2021 10:23 AM
18 replies so far
View Putttn's profile
Putttn
144 posts in 3333 days
#1 posted 03-05-2021 01:25 PM
I have a set and love them. I have the Incra I box I use it mainly with and it has been dead on and reversing them for bigger or smaller joints is a breeze. My joints are always tight and clean cuts even after years of use.
-- Bill eastern Washington Home of beloved ZAGS
View HokieKen's profile
HokieKen
17308 posts in 2194 days
#2 posted 03-05-2021 01:27 PM
I have not. But I’ve been considering the Freud box joint set for a while. I’ll likely buy it whenever the next project comes along that will require box joints.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
woodbutcherbynight
8797 posts in 3464 days
#3 posted 03-05-2021 02:10 PM
I have the Freud set, very accurate, easy to use. With Forrester I would expect the same.
View 75c's profile
75c
#4 posted 03-05-2021 02:14 PM
- Putttn
Thank you quote a recommendation! Thank you
Regards Tom
View 75c's profile
75c
#5 posted 03-05-2021 02:16 PM
- woodbutcherbynight
That’s good to hear. I have some Freud blades I love and others not so much. How old is your set? I almost bought a set when the first box joint set was introduced?
View 75c's profile
75c
#6 posted 03-05-2021 02:18 PM
I have not. But I ve been considering the Freud box joint set for a while. I ll likely buy it whenever the next project comes along that will require box joints.
- HokieKen
I have thought about them as well.
Regards Tom
View controlfreak's profile (online now)
controlfreak
1984 posts in 657 days
#7 posted 03-05-2021 02:37 PM
I need to loot at my Freud Dado set to see it it is flat or cuts “bat wings”. I also wonder if this will be compatible with my SawStop saw. I have a dado cartridge but have been told that not all dados are compatible. I was thinking about making some storage boxes for some of my tools.
View 75c's profile
75c
#8 posted 03-05-2021 02:43 PM
- controlfreak
Blades always worry me. I have hung blades individually each on there own peg board hook with space around them. That has taken up a bunch of room. The dado set I have is from dimar and it comes in a extremely well packed aluminum Case with foam between the blades. I need to come up with a different way of storing them so they are safe and take up less room. Wondering about a drawer setup like I saw on YouTube.
Regards Tom
woodbutcherbynight
#9 posted 03-05-2021 02:46 PM
That s good to hear. I have some Freud blades I love and others not so much. How old is your set? I almost bought a set when the first box joint set was introduced?
- 75c
6 months, big upgrade from Craftsman dado set. Have Freud dado set as well
View Andre's profile
Andre
4459 posts in 2861 days
#10 posted 03-05-2021 03:28 PM
Yes I do, was worth every penny when I bought it, not sure what they go for now?
Still as sharp and precise as the day I got it even after cutting a few box joints out of Plywood. Well guess it is a Forrest blade after all and not some cheap Freud :)
View 75c's profile
75c
#11 posted 03-05-2021 03:30 PM
- Andre
Thank you for the recommendation.
Regards Tom
View Bstrom's profile
Bstrom
341 posts in 228 days
#12 posted 03-05-2021 05:34 PM
- HokieKen
I too have the Freud box joint set – work very well and stay sharp long term. One of the few blade choices that have… it is used primarily as my dado cutter on a radial arm saw. Very handy setup.
-- Bstrom
View 987Ron's profile
987Ron
822 posts in 372 days
#13 posted 03-05-2021 08:43 PM
Me too. Agree with above.
-- Ron
View 18wheelznwood's profile
18wheelznwood
130 posts in 85 days
#14 posted 03-05-2021 09:16 PM
Just finished a set of storage boxes with a self made box joint jig. Much cheaper than the Incra version and definitely less flexible but it did a great job.
https://www.lumberjocks.com/projects/418970
View splintergroup's profile
splintergroup
4982 posts in 2277 days
#15 posted 03-05-2021 10:02 PM
I bought the Freud set when they first came out for around $60.
Mainly to cut 3/8” and 1/4” box joints, but lately I’ve been using it for far more. The cuts are exceptionally smooth and square, perfect for nibbling away at tenons where before I’d use a dado set or just a FTG rip blade.
The teeth are big chunks of carbide and tough. I was apprehensive when I needed a 1/4” shallow crosscut groove in the face of some maple I had just veneered. The tear out potential was high, but the blade cut perfectly.
