Blum hinge plate type
Forum topic by TigerFan07 posted 03-01-2021 06:21 PM 305 views 0 times favorited 8 replies Add to Favorites Watch
View TigerFan07's profile
TigerFan07
10 posts in 1368 days
03-01-2021 06:21 PM
I am planning on using Blum 110 degree self closing clip top hinges for some shop cabinets I’m building but I’m not sure the best type of hinge plate to use. I know I need the 0mm plate and I want a screw on version but there are still the one piece, two piece, and cam adjust plates.
Is one better than the other in terms of ease of install and durability?
Thanks
8 replies so far
View Madmark2's profile
Madmark2
2506 posts in 1643 days
#1 posted 03-01-2021 06:50 PM
Cam adjust.
-- The hump with the stump and the pump!
View LeeRoyMan's profile
LeeRoyMan
1683 posts in 782 days
#2 posted 03-02-2021 01:50 AM
I like the 2 pc wing plate 175H7100
View CWWoodworking's profile (online now)
CWWoodworking
1664 posts in 1234 days
#3 posted 03-02-2021 01:55 AM
- LeeRoyMan
+1.
View AlaskaGuy's profile
AlaskaGuy
6482 posts in 3364 days
#4 posted 03-02-2021 02:16 AM
View 1thumb's profile
1thumb
318 posts in 3212 days
#5 posted 03-02-2021 03:08 AM
- LeeRoyMan
why 2 piece? i use 1 piece, seems easier than a 2 piece
https://www.cabinetparts.com/p/blum-hinges-european-cabinet-hinges-BH173L6100-p6553
-- I actually have two thumbs. Both prehensile and opposing.
LeeRoyMan
#6 posted 03-02-2021 03:39 AM
- LeeRoyMan
- 1thumb
I like the 2 piece because it has the third hole for mounting. Plus you don’t have to loosen and re tighten the mounting screws over and over when adjusting.
I don’t like how the one piece just looks like a stamped out plate, although i’m sure it’s strong enough.
As far as ease, no different.
I like the plate AG posted, but I don’t like drilling my screws so close to the edge, (since most of my cabinets are of the european style) although the 6600 has the screws a little farther in. Plus for an inset door there just kinda weird. (and you have to knock the tits off)
1thumb
#7 posted 03-02-2021 03:57 AM
- LeeRoyMan
- 1thumb
I like the 2 piece because it has the third hole for mounting. Plus you don t have to loosen and re tighten the mounting screws over and over when adjusting.
I don t like how the one piece just looks like a stamped out plate, although i m sure it s strong enough.
I like the plate AG posted, but I don t like drilling my screws so close to the edge, (since most of my cabinets are of the european style) although the 6600 has the screws a little farther in. Plus for an inset door there just kinda weird. (and You have to knock the tits off)
- LeeRoyMan
+1
TigerFan07
#8 posted 03-03-2021 02:06 AM
How does the adjustment work on the two piece? Is it also a cam?
