03-01-2021 12:25 PM
Topic tags/keywords:
art
frame
wood
framing
hardboard
experience
skill
Hey guys,
I’m an artist & I’ve been using hardboard for years for fairly large artwork, and now im looking to approach more “muralistic” territory (5’x7’ to 8’x10’+) while continuing to use the material.
I want to kick some ideas around for the artwork support processing idea i have and see if anybody has additional ideas to my own and if what im thinking might pan out.
I’m “married” to Hardboard because its the only material thats remotely reasonable for regular use at these sizes (or example, dropcloth and anything similar and its set up just doesnt cut it for designer stuff here.). Its been used extensively in the past by large scale artists, so there’s a reputation. Other materials like ACM and plastics are off the table for either costs, accessibility or lack or archival quality, etc.
So, generally Hardboard is set up with artwork at scale by prepping the front by sanding and priming, typically after you’ve established a cradling, most often with the same types of lumber used with large canvases, (eg: good pine and fir, etc.) and finishing the edges for durability.
Here’s my deal: if im already getting so much hardboard for all this, is there any reasonable, and structually (these sizes can get heavy-ish) use strips of cut up Hardboard itself as cradle frame backing/battening here?
Gluing strips together with similar orientation to the lumber ive used conventionally is an idea i have had for this overall design, but I want to ask a bunch of actual seasoned wood workers if it’s pheasible proposition in any way.
The considerations and pressure hits with these guys when the sizes enhance and the weight goes up. Then, things like “flatness, and staying that way” follow. Chased by ways of actually hanging them with hardware or cleats. Edges with hardboard here are typically treated with wood glues to avoid damage and splaying.
I may in a position where lumber is the only logical option, but if strategic battening could work due to costs and somebody has a big-brain moment (I dont have many) please hit me with it.
Thanks yall
7 replies so far
#1 posted 03-01-2021 02:45 PM
It’s difficult to imagine a solution without seeing everything in person. I think you just might be up against something we all strive for. I want it large lite weight and flat. Is their a reason your not working off a canvas stretched over a frame. Good Luck
-- Aj
#2 posted 03-01-2021 03:23 PM
I’m not sure there would be any weight savings but the idea of a torsion box comes to mind. A google search on “torsion box construction” will illustrate the concept.
It may be that one could use thinner hardboard to recover some of the weight from the extra material.
#3 posted 03-01-2021 07:19 PM
I m not sure there would be any weight savings but the idea of a torsion box comes to mind. A google search on “torsion box construction” will illustrate the concept.
- sras
Without having had given it a Google yet, it might just be helpful. If its something thatd obliviate some cross-member usage on a large scale, I could see some stability increase and weight saves.
Thank you for the recommendation, sras. I’ll check it out
- Aj2
Right? Reading someone else say its a directive of many other creators at least makes me think ive got my head somewhat in the right direction. (Lol)
There’s a lot to the comparison and compromise to large scale stretched canvas and panels (hardboard), but a few key points are the cost, visual appeal and durability over time, with painting process being part and parcel of its use too.
Typically, you’re looking at around $650-1,000 for a havy-duty, big boy 12-20 oz. canvas from a supplier, not including shipping and construction when it gets home, whereas You’re chiming it at a grand total of about $70 from the hardware store for a hand made piece out of hardboard panel, if you know what you’re doing.
Also note the cost of either option in this case (art supports) logically has no reflection on actual quality in terms of archival-ability and overall structural integrity, and a great deal of artists actually recognize it as superior in those terms. The look too, imo, has a more modern presentation and i find lends itself to more modern work (i have a lot of stuff aimed at interior design.)
The labor element isn’t great on either if you’re making your own stuff, but hey it’s part of the fun. . . Right?
#4 posted 03-01-2021 07:31 PM
I’d go the Steve approach, very flat, stiff, and light weight for the end product. I’d have a hard time finding any hardboard over a standard 4’ x 8’ sheet however.
For glued up stacks of hardboard vs, just using pine, pine wins. It’d take too much time laminating up hardboard strips to get the same effect as pine.
#5 posted 03-01-2021 09:32 PM
I d go the Steve approach, very flat, stiff, and light weight for the end product. I d have a hard time finding any hardboard over a standard 4 x 8 sheet however.
For glued up stacks of hardboard vs, just using pine, pine wins. It d take too much time laminating up hardboard strips to get the same effect as pine.
- splintergroup
Yeap, I think you’re on the money there, splintergroup.
#6 posted 03-01-2021 09:38 PM
Hopefully I’m uploading this right:
Ok, so here are just a couple examples of stuff, just to get some visuals going. The first 2 pieces are what i was doing a while back before I started refining edgework and thinking bigger formats.
The last piece is halfway done, in both the art and the frame up itself, and its been my guinea pig for some 5’x7’’s here soon.
I had to do the ‘ole slats and clamps+water trick to straighten up some mistakes and cupping on the corners, but its leaning in the right direction.
Fortunately, the weight of it falls right on what a more robust canvas of this size, with say double fill weave at 20oz. Might likely weigh., with the additional “pro” of not having to eventually re-stretch or key back up later (to be fair, you wouldnt have to anyway for a decade at worst anyway with good stuff and proper set-up.)
I could shave off a few oz or so by bringing a bevel via router/chisel on the interior struts. As excessive as that might seem here, again we are trying to ring out weight savings where we can.
Last off, as much as I prefer the more shallow orientation on this (last) cradle versus the top, black guy’s “gallery wrap” profile, I fear there will be pretty obvious diminished returns on it going huge, but I hope I wrong yet again.
#7 posted 03-03-2021 12:35 AM
More food/thought, and please forgive the typos up top
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13250 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2831 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
580 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
417 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1914 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6408 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7948 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32963 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
335 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6491 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1826 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7313 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1647 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2645 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1273 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5439 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2401 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9686 |
