Finish cans won’t close
Forum topic by Erik07 posted 02-28-2021 08:05 PM 415 views 0 times favorited 10 replies Add to Favorites Watch
View Erik07's profile
Erik07
12 posts in 54 days
02-28-2021 08:05 PM
Has anyone had problems getting cans of finish to close properly? I recently got a new can of Rubio and couldn’t get the top to seat correctly. I originally thought maybe I dented the lip or something, but I just got a can of Briwax and am having the same problem. There’s no visible dents or defects as far as I can tell.
When I put the top of the can on, it seems like it goes down all the way, but it sort of just floats back up and I can easily pry the top back off with my fingernails. It’s like it doesn’t grip the lid after I open it for the first time…. anyone know what I’m doing wrong?
10 replies so far
View Rich's profile
Rich
6768 posts in 1640 days
#1 posted 02-28-2021 08:29 PM
I’ve run into that as well. It’s probably air pressure. Both of those materials will seal around the rim and lubricate it, so the pressure pushes it up. It’s more of a problem with nearly full cans, since the pressure increase is greater due to the smaller volume of air.
As long as it’s on well enough to be air tight, it’s OK.
View Madmark2's profile
Madmark2
2487 posts in 1639 days
#2 posted 02-28-2021 08:35 PM
Use the nailhole in the gutter trick to drain excess liquid. Use a block wider than the can and a mallet to seal the lid. Mallet the lid in three directions. Once seated, roll the can to slosh the contents around the lid on the inside.
-- The hump with the stump and the pump!
View John Smith's profile
John Smith
2886 posts in 1213 days
#3 posted 03-01-2021 08:33 PM
Erik – could you show us some clear closeup photos of the rims of the cans in question ?
people that use finishes or paint on a regular basis, take the time to really keep the rims clean
of any excess finish or paint.
are you the one that used the finish last ? is there any chance that the lids could have gotten mixed up with another brand of finish ? (that’s a long shot there).
I know a guy that couldn’t keep the rim clean to save his neck.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View SMP's profile
SMP
3773 posts in 956 days
#4 posted 03-01-2021 08:49 PM
I have had the same thing happen with Briwax cans, frustrating! I do the best i can and hope that with the plastic lid over it helps to keep it going bad. One can is duct taped since the plastic lid cracked
View 987Ron's profile
987Ron
784 posts in 367 days
#5 posted 03-01-2021 09:22 PM
- SMP
=1 on the Briwax. Reopened the can and the remaining wax was 1/2 the size of the can.
-- Ron
View Knockonit's profile
Knockonit
793 posts in 1253 days
#6 posted 03-01-2021 09:42 PM
i hate the new composite cans the big box stores are using, can’t get’m to seal at all with a tad of finish in the rim, ugh, give me a metal can any day of the week
Rj in az
-- Living the dream
View splintergroup's profile
splintergroup
4963 posts in 2273 days
#7 posted 03-01-2021 10:18 PM
i hate the new composite cans the big box stores are using, can t get m to seal at all with a tad of finish in the rim, ugh, give me a metal can any day of the week
Rj in az
- Knockonit
And make those gallon cans come with a spout installed in the lid. Too much of a PITA pouring a fresh gallon of lacquer into a filter cup for the sprayer 8^)
I know there are gizmos available for doing this, but the time has come for the paint can cabal to cede power!
View LesB's profile
LesB
2944 posts in 4493 days
#8 posted 03-02-2021 12:52 AM
Interesting as I have not noticed this problem.
Try this….. Oregon has a “recycle” deposit to keep unused paint out of the garbage (land fill) on all paint cans from $.075 to $1.50 depending on size. You only get it back if you return cans with left over paint and then some stores won’t take certain types of cans or paints and they must have their labels on. Some take metal cans but not plastic, some won’t take what they don’t sell.
-- Les B, Oregon
Erik07
12 posts in 54 days
#9 posted 03-02-2021 08:35 PM
Interesting, well I’m glad I’m not the only one! I’ll have to try cleaning the rim as a few of you suggested, although I’m the only one who uses these and should actually be pretty clean.
John Smith
#10 posted 03-02-2021 09:13 PM
on some finishes, it only takes a thin film to “cement” the lid in place.
I use a very high quality marine spar varnish that is on the high end of the price scale
and if i don’t clean the lid and the groove with a solvent soaked rag, it will stick like super glue.
so pay attention to the lid and the groove equally.
the plastic lid on plastic containers of some finishes/sealers will also give you fits.
