Keeping light wood from absorbing darker woods dust/color
Forum topic by Dselburg posted 02-28-2021 06:13 PM 340 views 0 times favorited 3 replies Add to Favorites Watch
View Dselburg's profile
Dselburg
1 post in 45 days
02-28-2021 06:13 PM
Topic tags/keywords: padauk heat treated ash maple question input advice woodworking help color spreading bleeding rookie cutting board cutting boards hardwood hardwoods tip tips skill trade
Hey y’all! My names Doug, and it’s my first time posting here. But I’m new to working with hardwood. Starting out getting my feet wet by making simple cutting boards for family as gifts. This may be a rookie question. But I’m really struggling with keeping the Maple wood from absorbing the dust and or color from the other darker colored wood. Example, heat treated Ash, or Padauk. Obviously it’ll take on a brown hue or red hue. And when I look at other folks boards or other projects. The maple is still white as ever! How can I get that finish.
My process . After glue up. I run through planer. Then Acetone, and compressed air. Next I start with orbital sander 120 grit. Then repeat acetone and compressed air before 220 grit sanding. Then compressed air, acetone, then light water spray to raise grain. Then 320 sanding. After that compressed air and then Mineral oil. Then after appointment time I put on Walrus wax.
Throughout the process I feel like I’m in an uphill battle to keep that maple a clean color. Any input would be appreciated! Thanks in advance!!
3 replies so far
View Aj2's profile
Aj2
3753 posts in 2848 days
#1 posted 02-28-2021 07:52 PM
There’s no secret Mr burg. If you sand the dust will cross between the woods.
One solution is no sanding, after planning clean up with a low angle plane or scrape the surface with a card scraper.
The other path and I thinks is the best use one species of wood.
Good Luck
-- Aj
View CaptainKlutz's profile
CaptainKlutz
4325 posts in 2545 days
#2 posted 03-01-2021 04:11 AM
Welcome to LumberJocks!
+1 no secret. Light/dark wood sanding challenges with cutting boards are tough.
+1 use scraper or hand plane and skip sand paper.
Acetone is capable of dissolving many natural dye colors. It might be part of your problem? Stick some Padauk wood chips/dust into cup of acetone and stir for couple minutes. Stop using acetone if you see color change in solvent. If you insist on using solvent, try paint thinner or Mineral spirits (and not the odor less stuff) instead.
Best Luck.
View tomsteve's profile
tomsteve
1158 posts in 2270 days
#3 posted 03-01-2021 12:45 PM
remove the acetone from the equation.
sand, compressed air.
since cutting boards use oil of one variety or another and you are using mineral oil, no need to raise the grain,too.
